Tip & How-To about Sylvania G-Netbook
How To Fix SYNET07526 WiFi By Flashing
My SYNET07526 WiFi quit working five days ago, The WiFi symbol down in the lower right corner, (the small computer icon with two radiating waves) showed that the WiFi was working , because the red X did not show up indicating a no connect.
I checked the connection by double clicking on that icon and a window RT28701 opened up with the Default Gateway missing its address. This Default Gateway is the address of your home network computer, usually 192.168.1.1.that it needs. Of course the WiFi is working but it cannot hook to a home network because it doesn't know where to send the signal. The RT28701 has some kind of flaw or the load was compromised. I had to down load the new SYLVANIA Smart Book Operating System Update: found at the left bottom of the page at:
http://digitalgadgets.com/netbooks/7-in-netbook.htm
Now this is a totally new update of the operating system that replaces what you have now. They have substituted the program word with another, along with some additional programs.
You must follow the directions to the letter using another computer to make the SD card and transfer the Script file to the root of the SD card. When you put the SD card back in your Net book and reboot, the program erases your existing system and installs the new one. Do not do this unless you are comfortable flashing your machine. There has been instances where the machine was erased and the up date did not take rendering the machine inoperative. A SD card of 1-2Gb can be purchased for about 10 bucks.
If you decide to do this, you should take your time, maybe ask some one else to help and keep track of what you do. Also look on the internet for information under Flashing the ARM 8505. You can keep a copy of the operating system on the SD card and re-flash if things go wrong again. Also, if you become proficient flashing, you can put other operating systems on your machine such as Android or Linux and go back to your CE. Again, seek help at first!
Just found a You Tube Video of a demostration of the usage of the SYNET07526 which is fairly concise. http://www.youtube.com/watch?v=0l_79tXqhac&feature=player_embedded#!
Sylvania G-Netbook Logo
I got a sylvania (synet07526-r) for Christmas but it won't let me connect to the internet. What I'm I doing wrong I have tried everthing????????
t is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Jan 01, 2011 | Sylvania G-Netbook
I cannot get internet connection on my Synet07526 notebook can you help I'm about to take it back to the store? Thanks! Rob
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
Dec 28, 2010 | Sylvania G-Netbook
will not play you tube which is built in to ce
I suspect that you are not connected to the internet. If you are trying to click on the icon "youtube" and it gives you a blank youtube screen, then you have to use the upper search and type in what you want, and get a "The server name or address could not be reached". you are not connected to the internet.
You have to first click on the WIFI Power icon and when it comes up click on the power on button which turns to power off, then the machine looks for a network and when it finds one it gives you an indication down in the right corner of a Computer Screen with radiating waves off to the side. If that small icon has a red X next to it the network is not on.
If you do get that icon of a computer screen with two radiating waves off to the side then you can hit the You Tube Icon and away you go.
Dec 03, 2010 | Sylvania G-Netbook
can't get on wifi sylvania 7 inch note book
You have to enable the WIFI button on the desk top, when you click on it it will show a power on button. when you click on that button it will turn to off, ready to turn off when you click it.
The machine will then hunt for a network within range and connect. Look for a small icon down in the right corner of the tray and see if you see a small computer screen with two radiating waves. this means that the machine has found a network and is connected. If you see a red X beside that icon instead of the radiating waves, it means you do not have a connection, If you have a connection then you can use the Internet explorer to go to a place on the internet.
The WiFi software that is embedded into the OS does not work very well. Fortunately digitalgadget.com has a download that somewhat fixes this problem fairly well. The new download is not totally goof proof, but you can work with it.
Go to: http://www.digitalgadgets.com/netbooks/update.html and download the indicated update. You can copy it to a thumb drive and connect the thumb drive to your Sylvania , find it under My Computer and then copy it to your
desktop and run it from there.
Nov 30, 2010 | Sylvania G-Netbook
26,781 people viewed this tip
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
