Tip & How-To about Computers & Internet
TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS WHENEVER YOU FORGOT THE PASSWORD
BIOS PASSWORD ARE USED TO SECURE YOUR COMPUTER BY PREVENTING OTHER USERS TO ACCESS YOUR COMPUTER'S BIOS SETTING OR MAKING IT UNBOOTABLE REQUIRING PASSWORD.
But in some cases, some people forgot the password.
HERE ARE THE TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS SETTING WHENEVER YOU FORGOT THE PASSWORD.
SOLUTION1. RESET THE BIOS PASSWORD USING DOS COMMAND PROMPT.
1. Go to start menu and choose RUN. For other operating system like Windows 7 and Vista, just use the search bar and type the command prompt. Right click mouse and run as administrator.
2. type the word "debug" and press enter
3. type the code "-o 70 2e" and press enter
4. type the code "-o 71 ff" and press enter
5. type the letter "q" and press enter
6. type the word "exit" and press enter
7. try to restart your computer and it will remove the bios password.
SOLUTION 2. TRICK THE COMPUTER TO GENERATE BIOS PASSWORD.
Some computer can generate bios password when you enter 3 different incorrect bios password. Below message will appear:
Password check failed
Fatal error...System halted.
CNU9117K31
Use the last line as password. CNU9117K31
SOLUTION 3. USE BACKDOOR PASSWORDS
AWARD BIOS
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet
AMI BIOS
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
OTHER PASSWORDS:
VOBIS & IBM - merlin
Dell - Dell
Biostar - Biostar
Compaq - Compaq
Enox - xo11ne
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
In TOSHIBA BIOS, just hold left shift key during booting process.
For IBM APTIVA BIOS, press both mouse repeatedly during the boot.
SOLUTION 4. CLEARING THE CMOS JUMPER OR DIPSWITCH SETTING.
Go to your motherboard and look for jumper should be located near bios chips or near the battery. THere is usullay 3 pin switch two of them covered with this jumper.
Procedures :
1. Turn off your computer.
2. Unplug the power cable from the power supply unit.
3. Wait for 30 mins to be safe that your motherboard is fully discharged.
4. Locate the jumper.
5. If there is 3 pin switches, the jumper shows would be in 1-2 position. Just place it in 2-3 position with a few seconds and then return it back to normal position 1-2 position.
6. If there is only 2 pin switch, just remove the jumper with a few seconds and then place it back to normal.
7. Connect all the connection and restart your computer. It it will reset the bios setting.
SOLUTION 5. REMOVING THE CMOS BATTERY
If the jumper switch solution doesn't work, try this solution by removing the cmos battery.
Procedures:
2. Remove power source cable.
3. Go to your motherboard and remove cmos battery.
4. Wait for 30 mins or more before returning it back.
5. Place the battery back correctly
6. Plug your power cable and start your computer and it is done.
GOOD LUCK AND I HOPE THIS WILL BE HELPFUL FOR OTHERS.
Computers & Internet Logo
How do I use the password protection?
Your questions isn't too specific but I hope this helps
There are several ways to incorporate password protection. You can set the computer to require a boot up password in the computer BIOS. You have to enter the computer BIOS as soon as you turn it on; with a Dell press [F2], with HP press [Esc] and select system configuration. In the BIOS you can set the BIOS Administrator password - controls the ability to change BIOS settings, the computer boot password - when enabled it requires the user to enter the bootup password before the computer will boot, and set the hard drive access password - controls the users ability to access a hard drive.
The next level of password protection is at the operating system level - account access levels, privilege levels, and passwords. Dependent of operating system you can also set hard drive encryption
Oct 28, 2014 | Maxell MAXDATA 503802 - FLIX8G HIGH-SPEED...
accer apire one d255e hardisk security lock
The BIOS (Basic Input Output System) is designed to check the integrity of the computer hardware and launch the operating system. The BIOS also has basic security features that prevent unauthorized access to the computer by locking the hard drive with a password. The password is required in order to launch the operating system. That option can be disable without an changes to the operating system.
Turn your computer on. Press "Esc," "Del," "F2" or "F8" to access the BIOS. Use the arrow keys to go to the "Security" tab. Press "Enter." Highlight "HDD Lock," Boot Password" or "Hard Drive password" using the arrow keys. Press "+" until "Disable" appears. Go to the "Exit" tab, highlight "Save and Exit" and press "Enter." Press "Y" when prompted to reboot your computer without the hard drive password.
May 05, 2013 | Computers & Internet
how to reset hp probook 4310s embeded security password
If your hp computer is installed with Windows 7, following the video to learn how to reset hp computer security password with Windows 7 Password Genius
https://www.youtube.com/watch?v=I5HzG7fb-Wg
If your hp computer is installed with Windows 8, and the password is your only admin password, refer to hp computer Windows 8 admin password reset.
Jun 20, 2012 | HP ProBook 4310s Notebook
How can I by pass Bios Password for Acer brand?
BIOS passwords are used to add some extra security to computers. You can either set a password to prevent access to BIOS settings or to prevent PC from booting.
But sometimes this extra security might become a pain when you forget the BIOS password or someone changes your system BIOS password intentionally.
But there is no need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing CMOS battery
  • By using motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Aug 11, 2011 | Computers & Internet
reset bios password
please give me lenovo sl400 bios reset password thanks
Oct 12, 2010 | Matsonic MS9158EP (DSMTSMS9158EP)...
4,636 people viewed this tip
David Payne
David Payne
