Tip & How-To about Computers & Internet
Changing Location of Images Folder
On your hard drive, the My Pictures folder, subfolder in My Documents, has a special status. It is this branch location that offers by default a lot of software when you want to read or record an image.
The My Documents folder is on the same hard disk as Windows (usually C:). However, if you have two hard disks (or two partitions), you may prefer that your images are placed on the second disc.
Open Registry Editor: Click Start ' Click Run ' Type regedit ' Press Enter Navigate to the following key: HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrent VersionExplorerUser Shell Folders
You should find several expandable string values such as My Pictures, Favorites which contain the locations of different system folders.
Note that for the My Documents folder, the value is called "Personal" and not "My Documents". To change the location of a system folder, double-click the value representing it, change its value data to your new location and click OK.
Remember to finally transfer all the files from their old location (My Documents My Pictures) to the new (D: Photos)
Computers & Internet Logo
does not allow transfer of files or pictures
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
Click on the "My Computer" icon on your desktop, and open the external hard drive.
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the photographs.
usually in my documents my pictures or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my pics 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the photo file, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
Sep 27, 2012 | SimpleTech Signature Mini 160GB External...
photos will not upload from camera to computer
Go to Desktop/MyComputer/Pana(or it may say USB Drive, or DCIM, and click on this external drive Icon.
You are now looking at the camera contents as if it were just another file folder on your PC, and behaves the same way.
You will find your pics in a sub-folder under a master folder, common for all camera file structures, named DCIM. You can drag and drop individual pic (jpg) files or whole pic subfolders from the camera to a place on your PC, usuallly Documents/Pictures.
You can do all other folder/file operations on this Camera Folder/Pic files you can do with those that exist on the PC like;cut, past, delete, rename, etc etc.
When you take you next first pic from your camera, after moving or deleting a pic subfoler under the Camera's DCIM master folder, the camera automatically creates another subfolder. Each subfolder holds 999 pics. The camera will atuomatically create a second, third, etc subfolder for pics 1000 to 1999, 2000 to...etc.
Nov 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
113 people viewed this tip
David Payne
David Payne
