Tip & How-To about Cell Phones
NOKIA ALL CODES
NOKIA Codes
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR) .
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
*#4720# With this Nokia code you can deactivate the Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type .
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI Number) .
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) .
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) .
*#147# This lets you know who called you last (Only vodofone).
*#1471# Last call (Only vodofone) .
*#21# This phone code allows you to check the number that "All Calls" are diverted to.
*#2640# Displays phone security code in use .
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to .
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to .
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible .
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered .
**67*number# Turn on "On Busy" diverting to the phone number entered .
12345 This is the default security code .
press and hold # Lets you switch between lines.
Author : JBJ
Cell Phones Logo
i want all secret cod of nokia n72 and all software code plzzzzzz thank you
*#06#
To check the IMEI.
*#0000#
To check the firmware version and date
*#92702689# *#war0anty#
To check the IMEI. The date when it was purchased
and the date when it was repaired.
*4720# (*hra0#)
To activates the Half Rate.
#4720# (#hra0#)
To deactivates Half Rate.
*#3370# (*efr0#)
To activates Enhanced Full Rate.
*#746085685# (*#sim0clock#)
To check the SIM clock status.
*#7220# (*#pca0#)
To activate the GPRS and Packet Common Control
Channel(PCCCH) supports.
*#7230# (*#pcd0#)
To deactivate the GPRS and Packet common control
channel (PCCCH)supports.
*#7760# (*#ssn0#)
To check the manufacturing serial number.
*#2820# (*#bta0#)
To check the Bluetooth MAC address
(Phone must have a built in bluetooth adapter).
*#7370925538# (*#res0wallet#)
Reset the mobile wallet.
NOKIA PHONE CODES :
Nokia Codes : *3370#
Nokia Codes : #3370#
Nokia Codes : *#4720#
Nokia Codes : *#0000#
Nokia Codes : *#9999#
Nokia Codes : *#06#
For
Nokia Codes : #pw+1234567890+1#
Nokia Codes : #pw+1234567890+2#
IDRISH 911
Nov 11, 2010 | Nokia N72 Cellular Phone
Code to increase my ringtone volume on Nokia 3110c without going to edit my profile cos i have some sticky keys (Down Key)
*3370# / #3370# Activate / Deactivate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
*#4720# / *#4720# Activate / Deactivate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
Aug 29, 2009 | Nokia 3110 Cellular Phone
191 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
