Tip & How-To about Computers & Internet
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
Computers & Internet Logo
How to hack Windows password on your netbook / laptop using a USB Flash drive
Well~ there are a lot of ways to solve your problem and I recommend you the best of them which is you use a software called windows password recovery and you can find it on http://www.recoverlostpassword.com/products/windowspasswordrecoery.html wish you good luck
Jan 06, 2010 | Computers & Internet
Re install your OS as there is no way in.HOW
You need to create a bootable usb drive. depending on what Operating System you want to install, you can easily find how to do that by googling "How to create a bootable usb drive for <your os>"
your OS could be windows xp, windows 7, windows 8, ubuntu, linux mint, manjaro, or any other OS you use for that matter.
You will find several ways to do it and not all of them will work for you. You may have to try about 4 or 5 different ways to do it before you strike one that works for you.
Nov 19, 2013 | LG X120 Netbook
i want to format my netbook because it has many viruses that make it work slowly
Right click on the partitions you want to format ( except the one you have installed the OS on) and click format. After that you should reinstall your OS, this will also format the partition where you have your OS installed.
Apr 09, 2011 | Computers & Internet
how do i install it without a cd
hi cool, are you asking weather how to install OS without CD or CD drive , if you want CD mean you can get it from local market lot of pirated version available in market, but its more best to buy licensed version to get full customer support.
IF you don't have CD drive mean you have another option USB memory card , but you have to make that USB memory card as bootable device for that you have to follow this steps
Download FreeDOS and make a bootable DOS USB Key.You have to used another system which have CD drive , put OS cd on that system copy the full OS on that CD to USB.
Now you can insert your USB to your laptop or pc and you can start to Install OS, but make sure you have to you have to select bootable device as USB drive.
Good luck ! if you think your problem solved don't forget to rate
Dec 31, 2010 | Computers & Internet
265 people viewed this tip
David Payne
David Payne
