Tip & How-To about Adobe Photoshop CS2
Speedup Photoshop CS2 use NexusFont with lots of fonts installed
Adobe Photoshop version CS2 and higher have a font preview option that will serious slow down your application if you have over 1,000 fonts installed in the windows fonts folder, simply uncheck this option in the type preferences.
I suggest that you install Xiles NexusFont FREE font manager to preview the fonts that you might like to use this will allow you to preview the typeface in Bold and Italics.
This way you can have as many fonts that you want installed I have over 5,000 and still have Photoshop running as normal without this little tweak even with a P4 with bags of RAM you will fail.
Its also a good idea to use Microsoft Font Validator in an attempt to find broken fonts this will give you a report on the glyphs and metrics for each suspicious font that you add tot he GUI, if you have over 1,000 fonts leave this running overnight.
MIRRORED HERE
Its also a good idea to save the workspace so that you can enter is again later
Computers & Internet Logo
using font from another application
Fonts from applications are installed in your font folder in windows and should be available to other applications installed.
Jun 11, 2014 | Adobe Photoshop CS5 Upsell from Photoshop...
Problems viewing all installed fonts in Indesign and Illustrator CS2
This is a common problem with CS2 and a variety of fonts.
Try using this missing fonts loader plugin:
http://www.proximasoftware.com/fontexpert/plugins/missingfontsloader.htm
If that doesn't work for you, let me know and we can try something more involved.
Oct 16, 2007 | Adobe InDesign CS2 for PC
problem with the "type engine"
Here are a couple of things to try. First, try uninstalling and re-installing the application / repairing. Typically, this problem occurs when some cleanup script or other thinks our spelling, hyphenation, or some other type data files aren't needed and deletes them.
If that doesn't work, search for and delete "adobefnt*.lst" files on disk. These are the font cache files and may have gotten corrupted. That's very unusual with more recent versions of Photoshop.
If that doesn't work, it's likely a corrupted font installed - there's a knowledgebase article on finding a corrupted font. You can find that on the Adobe website and follow it.
Dec 01, 2008 | Adobe Photoshop CS2 for PC
Photoshop fail to restart after changing font settings
sometimes adobe has a detect & repair on the menu under 'Help', or go to add/remove programmes and select your programme in the list and on the right where you would select uninstal ther should be an option to repair the installation, but you may need the cdrom.
Aug 21, 2007 | Adobe Photoshop CS2 for PC
1,992 people viewed this tip
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
