Tip & How-To about Dell Inspiron 5100 Laptop
Note book dell5100
No light cpu no turning nothing no even in standby nuthing coloud some help
Dell Inspiron 5100 Laptop Logo
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
First of all, I have a Gateway Model FX7026 desktop computer. My daughter was using it when suddenly the monitor screen becomes black. She tried to turn the computer on again but nothings happen. I open the computer and tried to plug the power cord and turn it on but nothings happen..The computer does not turn on. The following is what I have done and observed: (1)When I plugged the power cord to my computer, the motherboard standby led green turns on even not switching the computer power switch to on. (2)When I switch on the computer, the CPU fan will just rotate once and then stops also the motherboard standby led remains on. The power switch LED in front of my computer does not turn on. In other word, the computer does not turn on (3) I reset everything but the same problem. (4) Tried to remove one memory (Channel B-DIMM0)module, the video card, and other drives. I Just left one memory card and the motherboard with the CPU (with CPU Fan) and the chipsets (North Bridge and South Bridge). The same problem occurs with standby_led on. I even put a new memory(from my other computer) but the same problem. (5) Verified the PSU to be good by shorting the green and black wire of the 20-pin PSU plug. Still, Tried to use another PSU with higher power rating but still the same problem.. What seems to be the problem? Any help would be much appreciated.
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Mar 31, 2011 | Gateway FX7026 PC Desktop
onkyo ht-r670 receiver is new and will not turn on. red standby light is on. but no display. also remote doesn't have any effect.
I would check any fuses first. The power transformer could also be open.There is a stanby supply that provides 5 volts that is always on . This is what supplys voltage for the standby light and the cpu. When you press the power button the cpu trips the power on relay that provides the 120v ac to the main transformer. If the transformer is open nothing happens. Onkyp part # is 2301798. Check the windings for continuity.
Dec 31, 2009 | Onkyo Audio Players & Recorders
my gateway desktop does not want to start,
Check you bios configuration with Date and time correction.
See if your computer need cpu fan cleaning. Try to run F8 and scan your computer after you have accessed to safemode. Goodluck
JMC
Aug 15, 2009 | Gateway Computers & Internet
2,297 people viewed this tip
Alun Cox
