Tip & How-To about Heating & Cooling
How to clean gas heaters
Agas heater is a device that uses liquefied gas for heating. Since it isconnected to a gas source, cleaning it is quite easy. Keeping the gasheater in good condition by cleaning it from time to time is importantto prolong its durability. Cleaning the gas heater regularly is alsoimportant from a safety perspective, because deposits in the flue, oranywhere else in the device, can sometimes lead to problems.
    Checking
  1. If the gas furnace is not running, the power could be disconnected, the motor overloaded, or the gas supply insufficient. Check each of these components individually, ensuring the gas heater has sufficient power and that the motor is running (you will be able to hear if it is running when it kicks on). Check the gas reserves tank to ensure there is gas in it. If these systems function properly and you are still having difficulty, your heater may need to be cleaned or repaired.
  2. Cleaning
  3. If your heater is not heating properly, dirt in the gas lines--and especially the burner ports--could be the cause of the problem. First,disconnect the lever that connects the gas supply to the appliance. The burner ports are the parts that distribute the gas supply into the heater. They have to be cleaned with the help of a toothbrush or flask cleaner. The part called the burner access panel, which is located at the tank's lower part, may also have to be replaced if there is a dirt build up. This piece can be purchased at your local home improvement store and replaced according to the directions on the package.Generally, this should be replaced every two years.
  4. Filter
  5. If your heater is turning on and off repeatedly this could be caused by dirt in the filter or lack of lubrication in the motor or blower. Check your users manual to locate the filter (it is usually a large piece that slides in and out of your gas heater from the side), remove it after the gas has been turned off, and wipe off any excess dirt.Alternatively, you can replace the filter entirely rather inexpensively. Simply remove the filter, write down the model number and get a replacement from your local home improvement store.
Heating & Cooling Logo
Is 32c normal for the exhaust temp for a house propane furnace?
32 Celsius = 89.6 Degree Fahrenheit; sounds low:
Liquefied-petroleum gas-fired heating appliance with draft hood Exhaust Temperature: 360 (oF) 182 (oC) Reference link:
Fuels Exhaust Temperatures
Jan 08, 2015 | Heating & Cooling
gas dryer/ has just started taking long time to dry each load needing multible cycles of time. Is generating some heat, vent is clean, trap iis clean. What is keeping the dryer from heating up?
I suspect your gas valve coils are going out and need to be replaced. They can work when first used but later in the cycle one of them quits.
Sep 23, 2011 | Roper RGS7745PQ Dryer
Pentair Minimax NT Heater, this AM, come on with a bang, blowing the metal cover off the cabinet. Possible problem{s}? Dave
Rat nests inside the fire box or cloggs in the gas orface's going to the burners. Quite often this could be small spider webs that will look like lint.
If you have something keeping the gas from getting to the ignitor or the pilot instead of getting a smooth ignition the gas will build untill it reaches the ignition source, then boom. This will esaust all the oxigen and it will shut the heater down till it cycles again.
Hope this helps.
Feb 05, 2010 | Pentair Minimax NT Heater
leaks oil when mixing. the area where you put the beaters leaks a small amount of oil only when mixing.
The grease inside has liquefied instead of being a paste. This can happen by over heating the mixer, keeping near a heat source or a bad gasket. I suggest getting it repacked with grease and replacing the gasket before you start to ruin the gears.
Also the grease although not something you'd consider edible is food safe.
Nov 16, 2009 | KitchenAid K45SS Classic Stand Mixer
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
562 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
