Tip & How-To about Cell Phones
How to enlarge your iPad Dock by adding more applications
Your iPad Dock can authority up to 6 applications, not necessarily 4 as presented in absence settings. You can additionally alter the absence icons with fresh ones by removing the old ones, which absolutely aloof relocates them to the home screen. Here's what you accept to do to add applications to the Dock: tap the appliance and authority it until all the App icons alpha to "wiggle". Now aloof annoyance and bead it on the Dock.
Cell Phones Logo
change filter signal
Hi, Dim here is how to reset/adjust Engine Service Interval (Wrench icon)
Upon selecting this item, there are two possibilities. If the Wrench icon is active, you will have the opportunity to clear it--proceed directly below. If the Wrench icon is not active, then skip over the next section to "CHANGE ENGINE SERVICE INTERVAL".RESET WRENCH ICON:
1. The display shows CLEAr and no.
2. Press and release SCROLL to alternate between no and yES.
3. Select yES if you wish to reset the wrench icon.
4. Press and hold SCROLL for 4 seconds.
5. WS appears in the display.
6. Release SCROLL.
If you selected no, you will not proceed to the next section; the display will revert to the Service Setup Menu.
CHANGE ENGINE SERVICE INTERVAL:
To get to this point, the Wrench icon must not be active or you just now reset it, as above.
1. The display now shows either CLK or km/h (or Mph).
2. The display now shows the number of hours between Wrench icon reminders. The factory setting is "0044".
3.The 2nd digit of the hours value will be blinking:
In addition, the display also shows the Oil Can icon above the word "OIL", and the "CLK" indicator is present. The presence of "CLK" indicates the interval occurs based on time (this can be altered for the Wrench icon, but not for the Oil Can icon).
Good luck and have a nice day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 31, 2016 | Motorcycles
service light reset
Hi, Anonymous here is how to reset/adjust Engine Service Interval (Wrench icon)
6. Release SCROLL.
For more information about your issue, please visit the websites below. Good luck and have a nice day
Jul 01, 2013 | Benelli Motorcycles
I can't figure out how to change from right hand click to left hand. Please tell me how to do it. thanks
start run control panel mouse/ buttons/ configuration
press ok............
cheers
Mar 27, 2011 | Computers & Internet
New right-click menu item on Mac Os X
Add an Application to the Dock To simulate a right mouse button click while using a one-button mouse on a Mac, like to get a context sensitive menu for an object on the screen, hold down ctrl and click the mouse button while your mouse pointer is over the object.
If you enjoy the convenience of the Dock, you can make it even more useful by adding items to it you use regularly. Here, for example, you’ll find two ways to add one or more applications to your Dock.
Let’s say you’re currently using Keynote ’08, your favorite presentation software, and would like to keep it in the Dock at all times. Right-click on its icon in the Dock, and select Keep in Dock from the contextual menu that appears.
Or try this option. Open the Applications folder, grab Text Edit, and drag it to the Dock. Next time you want to use Text Edit, just click its icon in the Dock.
You can use this method to add multiple applications just as easily. In that open Applications folder, choose Calculator and Dictionary, two handy utilities, and drag both into the Dock.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 01, 2009 | Apple 13.3 MacBook Intel Core 2 Duo...
179 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
