Tip & How-To about Kenmore Elite 44173 30 in. Electric Cooktop
Best way to Fix Scratches on Your Radiant Smooth top Cooktop
Cooktops are in many homes and are a preferred kitchen appliance to many home owners. The Cook in the kitchen can appreciate the stylish look of a sleek radiant smooth top Cooktop . Many invest top dollar to have stainless steel appliances including the following: Refrigerator, Dishwasher and Compactor. Moreover, having a sharp looking Cooktop addition only compliments the style and design of any high end kitchen. Maintainence and care of such an essential attractive appliance such as a cooktop is important.
Here is the best way to fix scratches on your Radiant Smooth top Cooktop:
Step 1 - Prepare your Cooktop by cleaning the surface*Make sure the surface is cooled* Use a damp rag first and sweep of crumbs and food stuff. Use your favorite cleaner and rinse completely. Careful not to get moisture around knobs or switches. Dry off surface.
Step 2 -- Work on the scratch area
Run the sharp edge of a razor over the scratch around 3x and this will aid in smoothing out any raised ruff edges. Apply gentle pressure to the cooktop scratch area.
Step 3 - Apply A Cooktop Cleaner
Use a few drops of cooktop cleaner to the scratch area. Use a sponge to rub in cleaner. Use circular motions to allow scratch to absorb product. Run the razor edge over scratch again making sure not to apply to much pressure.
Step 4 -- Clean Cooktop surface again and remove cleaning product
Rise off cleaner and dry with a dry paper towel. Inspect scratch to test results. Repeat step 3 until you have desired results.
Special Note* Their are many ceramic cleaning products to choose from and many claim to be the best on the market. Be sure to choose one that has good reviews and then test the results. Special attention must be given to all radiant smooth top cooktops. Be sure to use only cookware that is recommend by the manufacturer. And be sure to clean spills as soon the cooktop is cooled to keep the appliance looking well. Deep scratches or pits cannot be removed or buffed out and may lead to a cracked cooktop.
Kenmore Elite 44173 30 in. Electric Cooktop Logo
GE cooktop ignitor jgp
Look for a short in the wiring (usually white wires running to the ignitors) or a loose ground wire. (usually green)
Jul 02, 2012 | GE Cooktops
Looking for a manual for Russell Range cooktop Model #SFC-36-6.
I have the same Cook Top RUSSELL RANGE 36-6 with a defective spark Module. part # kool lite 6521
I found the owner in SAN FRANCISCO Russell Zipkin
Now under SELECT APPLIANCES 1 888 235 0431
They were of no help at all.
Feb 26, 2010 | Cooktops
No fault with the product, seeking a copy of the owners manual
hi my name is mark, go to www.managemyhome.com find home manager at top of page. click on owners manuals. then type in brand in searh box and then look for your model. thanks for your question.
Mar 14, 2009 | Cooktops
induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 14, 2008 | Dacor Millennia ETT304 Electric Cooktop
1,770 people viewed this tip
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
 Fix Your Board
Fix Your Board
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
