Tip & How-To about Apple iPhone 3GS Black (16 GB)
How to check iphone firmware version and iphone baseband
To check the firmware and baseband on the Iphone
This is for Iphone 4, 3gs and 3g
1) tap on settings
2) Tap on general
3) Select About
4) go down and look for "modem firmware" and that will be your ( baseband version)
5) to find the firmware look for "version"
And that's It.
Apple iPhone 3GS Black (16 GB) Logo
3g not working on iphone 5c, I need settings
Try to
Check for a Carrier Settings Update by Tap Settings > General > About, Check for an iOS Software Update by Tap Settings > General > Software Update, Remove the SIM Card and reinsert it ,Allow the iPhone to acquire the network again, Reset network settings: Tap Settings > General > Reset > Reset Network Settings ,Restore the iPhone as new http://support.apple.com/kb/HT1414. if still not able to solve and need some technical guidance then follow Mac Customer Service .
May 30, 2014 | Apple iPhone 3G
How to UNLOCK iPhone 4, 3GS, 3G or older - iOS 4.0.1 (all baseband)
pls help...i already unlocked my iphone 3gs version 4.1 with baseband 06.15.00 using ultrasn0w but it only shows the carrier name but still i cant call or contacted... what should i do???
Aug 09, 2010 | Apple iPhone Smartphone
my iphone will not pull up any of my emails or send an email
If iPhone is unable to send or receive mails, try these basic troubleshooting steps.
1. In Settings, turn on other SMTP servers
1. Tap Settings > Mail, Contacts, Calendars and under Accounts, tap the account from which you're trying to send mail:
2. Scroll down to where it says Outgoing Mail Server and tap the box where it says SMTP:
3. Scroll down to where it says AT&T SMTP Server, and tap it turn it on.
or
Turn on all other SMTP Servers.
2. Add your email account on iPhone instead of syncing your mail settings from your computer
1. Tap Settings > Mail, Contacts, Calendars and under accounts, tap Add Account.
2. Follow the instructions. When you enter your email address, iPhone will look up your service provider's settings for you. If iPhone can't find your service provider's settings.
3. Turn iPhone off and then on by pressing and holding the Sleep/Wake button for a few seconds until the red slider appears, then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
To turn iPhone on press and hold the Sleep/Wake button until the Apple logo appears.
4. In Settings, turn off Wi-Fi to only use the cellular data network
1. Tap Settings > Wi-Fi and turn off Wi-Fi.
2. From the Home screen tap Mail.
Nov 21, 2009 | Apple iPhone 3G
set up with iphone3g
1.: Power on your iPhone 3G (if you have not already done so)
2.: Slide to unlock your iPhone 3G (if you have not already done so)
3.: Tap "Settings"
4.: Tap "General"
5.: Tap "Bluetooth"
6.: Make sure Bluetooth is enabled, by setting the toggle to "ON"
7.: Make sure your headset is discoverable
8.: When it shows up on your iPhone, tap it
9.: If prompted for a passcode, enter "0000" (if the headset instructions list a different passcode, use it instead of "0000")
Your headset should now be paired.
Sep 09, 2009 | SouthWing SA505 Bluetooth Headset
Unlock iPhone 3G Baseband 2.30.03
Jailbreaking is possible. But not software unlocking. For that you must buy something like a Turbo Sim. For jailbreaking try the program called Quickpwn
Jun 05, 2009 | Apple iPhone Smartphone
1,067 people viewed this tip
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
