Tip & How-To about Cell Phones
Shut Down Your iPad For Real
When you press the power button on the iPad actually turns off just the monitor. That's why we talk so fast. What can be done to conserve battery power, or to recover from the freeze is to reboot the system. To do this simply by holding both the power button and the Home button until the red slider appears. Press and turn the iPad. Give it a minute and you can reboot by pressing the power button. It seems that a few seconds before responding so be patient.
Cell Phones Logo
How do I unfreeze my Apple ipad air ?
It's actually very easy, once you know how to do it. Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom).
Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
May 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
can't get ipad to slide open for the password
Hi Teresa,
Press and HOLD Power button then press and hold Home button without leaving power button. This will restart your iPad and hopefully this issue will be gone. If it doesnt then please let me know, I can guide you through another solution.
Good luck.,
Apr 01, 2014 | Apple iPad (16 GB) WiFi Tablet PC
got a black screen ....how do I get back to the previous page?
Hi.
Here are some solutions for your problem provided by apple.
Resolution
If a single application is not responding or freezes when it opens, you can force it to close:
  1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button.
  2. Instead of dragging the red slider, press and hold the Home button for six seconds.
  3. If the device does not return to the Home screen, see the steps below to restart.
If the iPad is unresponsive or certain controls aren't working as expected, try restarting the device:
  1. To turn iPad off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPad.
  3. To turn iPad on, press and hold the Sleep/Wake button until the Apple logo appears.
If the iPad remains unresponsive or does not turn on (or power on), try resetting the device:
  • Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
If there is no video on iPad, verify that it has enough charge to turn on:
  1. Connect iPad to the 10W USB Power Adapter with the Dock Connector to USB Cable.
  2. Let iPad charge for at least 20 minutes, then see if it starts up normally.
  3. If there is no image on the iPad screen, press the Home button to attempt to wake the device.
  4. If the iPad screen displays a red battery icon, let the iPad to continue to charge until it turns on.
Aug 28, 2011 | Apple Ipad I-pad
my walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola brand.
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
140 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
