Tip & How-To about Computers & Internet
How to remove "Flash drive write protection" error appears in Windows XP
Why do you get a "The disk is write protected" error when attempting to transfer files to USB flash drive?
Permissions in the PC may have restricted writing files to the USB flash drive. Disabling restrictions should fix this issue.
WARNING: Backup your registry before editing.
STEP 1 - Backup the registry
1. Unplug the USB flash drive. 2. Click Start > Run, type in regedit then click OK. 3. From the registry menu, click File, select Export. 4. Under Export range select All. 5. Name the file backup.reg and save it to the desktop.
STEP 2 - Disable the "Write Protect" permission in the Registry
1. On the left pane, click the "+" beside HKEY_LOCAL_MACHINE 2. Navigate to SYSTEM > CurrentControlSet > Control > StorageDevicePolicies. 3. On the right pane, right-click on WriteProtect and select Modify. 4. In the Value data field, type the number 0 5. Click OK.
Good Luck
Computers & Internet Logo
Recently , you purchased a USB flash drive that you plan to use to store work-related files. When you attempt to store a file on the USB flash drive, the computer displays an error message indicating that the file will not fit. How could a brand new flash drive not have enough room to store the first file you attempted to store on it?
You failed to mention what operating systems are involved. What does the work computer use as an operating system. The file system format of the USB may be say as an example ntfs windows while as a hypothetical the work computer could be apple o/s using a different file system or even maybe a unix system. You may need to reformat the usb stick to be the format file system used by the work computer. Also there could be a policy in place to prevent usb sticks working on work computers to protect intellectual property or to protect against virus transferance.
Sep 25, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
how to remove write protect on my usb flash drive
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope it helps
Apr 18, 2012 | SanDisk 2GB microSD Memory Card
device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
On USB sticks there is a small switch which should be unlocked before you attempt to format. That is exactly what the switch is for... to prevent you from formatting and possible deleting valuable information.
Another issue could be
5.Name the file SNDK.reg and save it to the desktop.
5. Click OK.
Nov 25, 2010 | Computers & Internet
1,564 people viewed this tip
David Payne
David Payne
