Tip & How-To about Pool & Spa
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
Pool & Spa Logo
It moves about 1 ft. (if any) and then stops! I've checked for clogs, etc. I rent this house and owner knows less than I do!! Thank you!
If I were in your shoes, I would get permission from the owner to call a pool professional in to look at the pool in general and the device in particular. There is a lot to know about running a pool beside the swimming part. Water chemistry is crucial. You must do something to the pool on a daily basis. If you don't know what, you need to learn and your pool service company can teach you in a short amount of time.
Apr 30, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
ps3 powers up momentairily and then turns off.???
Hey I had same problem as well. It's kinda difficult to get through with this problem, it ain't easy. You probably want to get hands on some professional guide that teaches you how to fix it by yourself, especially the guides that are newbie friendly. http://ps3yellowlight.org has some nice reviews about the guides, you can check reviews before buying one!
Jun 29, 2010 | Sony PlayStation® 3 (60 GB) Console
Yellow light comes on indicating failure on PS3
Jun 21, 2010 | Sony PlayStation® 3 (80GB) Console
i need to cancel the theftproof and i forget my own password for factory restore
There is no password for factory restore. If you're trying to get into a computer with a password that you do not know, take it to a professional computer repair shop. They can get into it after you show proof of ownership. If you have no proof of ownership, maybe you should give it back to the rightful owner.
Sep 15, 2009 | Computers & Internet
984 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
