Tip & How-To about Irons
Getting a fast fixya.com reply
I have seen many questions posted which cannot be answered simply for lack of basic details.
It is understandable - you have a problem which needs a rapid response. In frustration, you post a brief description of your problem just to get it out there. But this reduces your chances of getting a response at all.
I therefore advise that you try to take the time to provide good information such as make and model, your observations of the problem and steps you took to reach the problem, what else you have tried etc.
For example instead of saying "Iron won't turn on", try:
"My Rowenta DG-980 does not heat up. When I switch it on at the wall plug, the red light is off. If I adjust the thermostat dial, it clicks at a certain point, the red light comes on but still the iron does not heat."
I hope this helps in enhancing your chances of solving your problem.
Cutonthenet
Irons Logo
Why have you not answered my question
Because I havent seen your question
Oct 16, 2014 | Tefal Irons
I was ironing my clothes and i was out of water. I added more and the iron cut off on me. Now when i plug it up it wont even come on.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealersip.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 08, 2010 | Euro-Pro Shark GI490 Iron
Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
1,403 people viewed this tip
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
