Tip & How-To about Cell Phones
BlackBerry Error Code
When using the BlackBerry device simulator, you can sometimes meet this Application Error inside JVM Access Violation Reading 0x00000000 when you try to start the simulator. Here's how to solve your problem.
BlackBerry simulator ERROR:
  • Application Error
  • Error inside JVM:
  • Access violation reading from 0x00000000
Open the folder to install the simulator BlackBerry for example: C: \ Program Files \ Research In Motion \ BlackBerry Smartphone 4.6.1 simulators \ 4.6.1.199 (8900) if there is a file called clean.bat use it. Try to open the simulator, and if you get Error inside JVM: Access violation reading from 0x00000000 error again, close to the simulator, open the installation folder again and delete all. DMP files to be installed in the folder and start the mortgage again.
If this fails, try the following:
  • Uninstall the JDE SDK and the BlackBerry Simulator
  • Reboot your PC - do not bypass this step
  • Install JDE SDK and the BlackBerry Simulator
  • Start the Simulator
  • Posted by on
    Cell Phones Logo
    I have balckberry Bold 9700. I have problem "JUM ERROR 102" Please help me.
    i have the same phone. its JVM error 102 and you'll also get uncaught exception java.lang errors more than likely. its caused by a coruption in the software. its nothing you did, the software just failed. you can call your provider and do an exchange but it takes forever!! if you have a computer you can run the application loader and it will 100% FIX the issues. it saves all your info, wipes the old software, and reloads all the brand new software. this is from tmobiles website t-mobile.com/forums
    Most JVM errors on a BlackBerry, can be fixed by simply reloading and updating your device software. For instructions on how to reinstall or upgrade your BlackBerry software, please see: HOW TO: Install New Software and Update (Application Loader) - BlackBerry®
    There are some JVM errors that can not be fixed in this method, if you do encounter one of the below JVM errors, please call customer care at 1-800-937-8997 or 611 from a T-Mobile phone for further troubleshooting.
    • JVM Error 501
    • JVM Error 517
    • JVM Error 535
    • JVM Error 547
    • JVM Error 548
    Didn't find an answer to your problem? Post about it in our BlackBerry Forums
    Help us improve this article, please leave a comment.
    Take me back to the BlackBerry Knowledge Base
    ***This link will show you how to reload new software with screen shots and a video!!!
    http://forums.t-mobile.com/t5/BlackBerry-General-All-Devices/HOW-TO-Install-New-Software-and-Update-Application-Loader/ta-p/306005
    ***when this helps please give me credit and rate me appropriatlly, please!*****
    Jan 03, 2011 | Cell Phones
    it won't come on it just says Jvm 513 reset
    Thank you for using Fixya1
    Based on www.blackberry.com the error message you are getting is due to typing incorrect password for a couple of times (10 or more).All of the data and applications on the BlackBerry smartphone have been deleted.
    The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone. For instructions, click HERE
    Note: Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader.
    May 24, 2010 | AT&T Blackberry Curve 8300 Smartphone
    errror message JVM error 102 appears on screen
    Problem
    The BlackBerry smartphone stops responding and displays the following error message:
    JVM Error 102
    Cause
    A problem exists with one or more of the .cod files on the BlackBerry smartphone.
    Resolution
    Before completing this resolution, download and install the latest version of BlackBerry® Device Software from your service provider's web site.
    Re-install the BlackBerry Device Software and applications to your BlackBerry smartphone by completing the following steps:
    Warning: The following procedures will delete either all data or all data and applications from your BlackBerry smartphone. Back up your data before performing the procedure. For instructions, see KB12487.
    Connect your BlackBerry smartphone to your computer.
    Open BlackBerry® Desktop Manager. Note: BlackBerry Desktop Manager may display "Disconnected." If this is the case, proceed to the next step to correct the problem with Application Loader.
    Click Application Loader. The Application Loader Wizard appears.
    Click Next.
    Choose the port that the BlackBerry smartphone is connected to and click Next.
    If prompted, type your BlackBerry smartphone password and click Next. The Device Application Selection screen appears.
    Select the applications that you want to install on your BlackBerry smartphone.
    If the Device Backup screen appears, choose whether or not to automatically back up the data on your BlackBerry smartphone. Click Next.
    Click Next.
    The Completing the Application Wizard screen appears, displaying all the software that will be installed on your BlackBerry smartphone. Click Advanced and make sure that Erase all application data and Erase all currently installed applications are both selected.
    Note: If the application loader tool was not able to access all of the data on your BlackBerry smartphone, then the following two fields are grayed out: Erase all application data and Erase all currently installed applications.
    Click Next.
    Select Do not automatically create a backup and click Next.
    Click Finish. The BlackBerry Device Software will be installed on your BlackBerry smartphone. Do not disconnect your BlackBerry smartphone until the process has completed.
    Axl
    May 04, 2010 | RIM BlackBerry Bold 9700 Smartphone
    JVM ERROR 513 BLACKBERRY 8310
    JVM 513 indicates all data and application on the device have been deleted. To restore, you need to reinstall the Blackberry handheld software and restore the data from the backup file if you have it on your computer. To reload the software, you will have to connect the device to the computer and run Blackberry desktop manager and then application loader. In case you do not have thse software on your computer, check with your service provider and they will have the software available for free download on their website.
    Nov 28, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
    JVM Error 102
    This is a Java Virtual Machine Error with your blackberry OS. you will need to download a BB OS from Blackberry.com and then runn Apploader from your Desktop manager software. This will wipe and replace the BB OS and fix the issue.
    Sometimes a Hard reset can fix this issue though.
    If you need further help, please visit www.blackberry.com/btsc
    Jul 06, 2008 | RIM BlackBerry 7290
    437 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
