Tip & How-To about Health & Beauty
How to to replace batteries in Remington MS-5200 Electric Shaver
Hi, to change the batteries you will need to remove the back cover. There are 3 screws. 2 can be easily seen. The third is under the trimmer wher it hinges to the shaver. You will need to carefully pry out the trimmer to get to it. Once screws are removed, you can take off the back. Inside, remove the metal clip to access the batteries better. Then, unsolder the wires from the battery tabs. Install new batteries by soldering to wires. Reassemble in reverse order...
Health & Beauty Logo
how to replace battery on a black and decker cordless trimmer
  • Remove battery pack
  • Unscrew screws with Philips #2 to remove cover plate
  • Suggest you take picture with smartphone / digital camera of layout before removing battery, so you can easily pit back correct
  • Remove battery - you can easily get a replacement at Batteries & Bulbs or online.
  • Replace battery
  • Reassemble per picture
  • Put cover back on
  • You should be good to go
Jun 04, 2014 | Black & Decker Cst2000 12 - Volt Cordless...
can i and how do i change a rechargeable battery on a Remington 9100? Where can i buy the battery assuming this can be done
You will find batteries at shaveroutlet.com. I have provided links below. Your shaver has either NiCd or NiMh cells. You will need to order the correct type and you will need to order two batteries
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
or
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change them you will need to remove the back cover. There are 3 screws. 2 can be easily seen. The third is under the trimmer wher it hinges to the shaver. You will need to carefully pry out the trimmer to get to it. Once screws are removed, you can take off the back. Inside, remove the metal clip to access the batteries better. Then, unsolder the wires from the battery tabs. Install new batteries by soldering to wires. Reassemble in reverse order
Sep 22, 2010 | Remington Health & Beauty
how to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
My shaver will not hold a charge. What could be the problem
Remington model R-9500
Your shaver will not hold a charge because the shavers internal batteries need replacing. If you know how to solder, you can do it yourself or you can have it professionally done. You can purchase batteries or professional repair service from shaveroutlet.com. See links below.
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
If you feel this is something you want to try yourself, you will need to remove the back cover of the shaver. You will easily notice two screws on the back. There is a third screw that is near the very top on the back and it is underneath the trimmer where the trimmer connects to the shaver. Remove these 3 screws to take off the back cover.
Inside you will see the batteries. You will need to remove the metal clip that helps secure them into place. You will then need to use a soldering iron to remove the wires from the ends of the old batteries. Solder the new batteries to the wires and put everything back together in reverse order
Once the job has been completed, charge the new batteries for 24 hours.
Jan 24, 2010 | Remington Titanium SmartSystem R-9500...
I Have Honda Shadow 400s. My battery is dead adn I want to replace it but cant locate it. i removed the side covers and its not their. I assume its under the sit but after I remove all screws sit still dont come off. so to summerize my 2 question are: 1. Where is the battery and how do I change it? 2. How do I remove the sit if needed? Appreciate the help. Tnx Shay
Hi and welcome to FixYa,
To your concern:
  • Where is the battery and how do I change it?
Under the seat inside the battery box. In some versions, there are 3 Phillips screws that hold the cover. Pls note the location of the +/- battery terminals. Not all batteries have the same location/position of the terminals. If the battery has not been replaced for some time, dipping the battery terminal connector in very hot water would remove corrosion.
  • How do I remove the sit if needed?
If I remember right, just 2 Allen screws (left & right) between the seat and pillion (rear/passenger seat). I have seen version where there is a third screw at the back of the pillion. Once all screws are removed, lift the rear seat slightly and pull back (towards the rear of the bike). The front/driver seat also would require a slight lift and pull back.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | 2002 Honda Shadow 400
1,662 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
