Tip & How-To about Televison & Video
How to Safely Clean a Tape Video Head
If you are not getting video from a VCR, 8MM camcorder, or Digital Video recorder camcorder but get audio, do the following:
1. Use a brand new tape - right out of the package and insert it into the drive.
2. Perform a record on the tape - set it to do a RECORD (not playback).
3. Allow it to complete through the entire tape without stopping.
4. Upon completion - allow it to rewind.
5. Insert a known good prerecorded tape and play - observe the image. If it's good, then the head was just dirty and is now clean.
You may perform the above as often as necessary without any damage to the device.
Televison & Video Logo
HAVE CCD-TRV22 , WHAT VIDEO TAPE NUMBER DO I
Though 8mm filming was and still is the best safest way to make movies Sony have stopped producing 8mm tapes, I use the brand new Digital 8 tapes on my brand new Sony camera, would never dream of going over to Hard drive/SD card/DVD recording cameras as the image will not last as long as it will on 8mm tape.
Also the 8mm cameras are much better made than anything since 2006.
If you type 8mm movie tapes in your search engine you will find 100's of firms still selling your tapes, they will help you choose the right one ok?
May 25, 2010 | Sony Handycam CCD-TRV22 Camcorder
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Multi-function DVD recorder VRD-MC5
Update to my 1/8/08 posting - my recorder is working perfectly! I found the installation of the needed file quite easy and all is good in the hood.
Later
Nov 10, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
1,812 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
