Tip & How-To about Washing Machines
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
Washing Machines Logo
whirlpool washer age
Your washer was manufactured in March of 1993. The manufacture date is determined by the Serial Number. The second letter "C" represents the YEAR of manufacture. The first two numbers "14" represent the WEEK it was manufactured. The 14th week puts the manufacturing in late March. I hope this helps you.
Sep 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top wash rack doesn't get water
does the unit have a half load selection? if so then it may be stuck in half load due to a faulty solenoid in the base.
Mar 14, 2009 | Dishwashers
GE Washer top-load WLDSR416FOWC
Actually, I think I do remember having one do this before, and I believe on these GE models the spin cycle goes through the water level switch, so if your water level switch is sticking, then it won't spin, thinking its still full of water.
Here's the water level pressure switch for your model:
Manufacturer part#WH12X10065 is RepairClinic item#2205
don't forget to rate me in main page,it is the only way i get paid for my works..
Jul 23, 2008 | GE WDSR2080D Top Load Washer
1,528 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
