Tip & How-To about Dryers
Duet HE Dryer Notes and service manual
The duet dryer can be easily repaired by anyone with a repair manual. The tech sheet is located in a jacket inside the base plate on most models.
DUET DRYER SERVICE MANUAL
Dryers Logo
Maytag 4000 series front loading high efficiency clothes washer. When you select your type of wash and hit start, you hear a "click," then nothing happens. About 15 seconds later, both the digital tim
The diagnostics tech sheet is in a jacket inside the base plate. While you have the plate off goahead and get the junk out the pump filter. Follow the suggestions in the tech sheet. DUET SERVICE MANUAL
Nov 12, 2012 | Washing Machines
How do I clear error code F-28 on my Whirlpool Duet Sport electric dryer?
The tech sheet is located under the kick /service panel in a jacket. Suggetions and codes are in it. Duet sport service manual
Sep 30, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
maytag neptune dryer has e5 error code
I looked up your model and there is no E5 error code listed in the tech sheet.
Download a copy of your tech sheet here.
files.me.com/appliancejunk/e8bg66
When I search the maytag data base this is the service manual it list for your model number.
http://appliancedigest.com/index.php?/files/file/81-16023110-maytag-sloped-front-dryer-repair-service-manual/
If the dryer is running but not heating then the relay on the control, ignitor or thermistor are the most likely causes.
Aug 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have Whirlpool Duet dryer,model GEW9200LQ0. At first, it would stop drying when I set it on a particular drying mode (permanent press,delicate, etc.)but it would stop before the clothes were dry. Then, I set the dryer on Manual mode, but when I start the dryer, it stops after maybe 5-10 minutes. I looked at the tech sheet for the dryer, and error code E3 that is showing up on my dryer looks to be something I don't have the time/expertise to do. The tech sheet says : "If the E3 error code is displayed, there is a user interface or software mismatch. It is also possible that a component on the console electronics or the machine control electronics has failed" What kind of repair costs am I looking at? Am I likely to have a huge repair cost b/c of some expensive electronic part?
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
1,455 people viewed this tip
Top Dryers Experts
