Tip & How-To about Sony FD Trinitron WEGA KV-32FS120 32" TV
How to Unlock a Jensen TV
This is a brilliantly simple solution to a highly frustrating problem.
The issue of course is made difficult only by the fact that TV manufacturers all use several different ways to lock and unlock the Parental control which effectively disables the TV! If you do not have access to the information you do not know what combination of buttons is required to return the TV to normal function.
To remove the lock on the Jensen simpy press and hold the Display Button on the remote for at least 3 seconds whilst pointing it at the TV.
The lock will be removed and the TV will resume normal operation. Simple!.
Please do leave a vote for the solution. Thanks for using FixYa
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Where can I download a free manual?
There is a thing called THE INTERNET. It is BRILLIANT! (You're using it right now, in fact!)
Use Google or Yahoo, and you can find the manufacturer's website. On there, they will have resources such as Customer Service and downloadable manuals!
IMAGINE! :)
Seriously, though, we do not have any manuals here...
May 12, 2015 | Cell Phones
tv picture upside down
I do not know how strong experience do you have in electronic.
But the problem is very simple.
You must inverted the wires plug in the yoke of the picture tube.and Ready.Of course I am supporting the fact that everything is right in the electronics(inputs).
As you know any Set of TV, has 4 input signal to the CRT, 1)Audio 2)Video 3)Vertical Osc 4)HV or horizon the 2+3+4 signal is coming to the Yoke to TV CRT.
Please Do with very carefully and patience for to avoid electrical shock.
sincerely.
E.CUADRA
MANAGUA,NICARAGUA.
Oct 11, 2011 | Epic View 550 Treadmill
I have a WD-65732. The brightness level is very low dispite the fact the setting are on BRILLIANT and the bright level is high. Please help.
Howdy,
I suspect a bad lamp part # 915P020010. When you order it from factory it will give you detail information on how to install and handle.
Good Luck, Big Irish.
Nov 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
1,961 people viewed this tip
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
