Tip & How-To about Televison & Video
How to Remove Parental Lock on a Jensen TV.
This is a brilliantly simple solution to a highly frustrating problem.
The issue of course is made difficult only by the fact that TV manufacturers all use several different ways to lock and unlock the Parental control which effectively disables the TV! If you do not have access to the information you do not know what combination of buttons is required to return the TV to normal function.
To remove the lock on the Jensen simpy press and hold the Display Button on the remote for at least 3 seconds whilst pointing it at the TV.
The lock will be removed and the TV will resume normal operation. Simple!.
Please do leave a vote for the solution. Thanks for using FixYa.
Televison & Video Logo
Where can I download a free manual?
There is a thing called THE INTERNET. It is BRILLIANT! (You're using it right now, in fact!)
Use Google or Yahoo, and you can find the manufacturer's website. On there, they will have resources such as Customer Service and downloadable manuals!
IMAGINE! :)
Seriously, though, we do not have any manuals here...
May 12, 2015 | Cell Phones
I have a WD-65732. The brightness level is very low dispite the fact the setting are on BRILLIANT and the bright level is high. Please help.
Howdy,
I suspect a bad lamp part # 915P020010. When you order it from factory it will give you detail information on how to install and handle.
Good Luck, Big Irish.
Nov 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
VCR part not responding
This is a common problem. Also the DVD unit has a High failure rate due to the spindle motor going bad. CD's may spin very slowly or erratically and sometimes the CD might be hard to eject. The VCR may be very difficult to get out to work on, and I doubt that it is a broken or loose belt that is causing your symptoms so you will probably be better off just replacing it.
Dec 24, 2006 | Samsung DVD-V4600 DVD Player/VCR
233 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
