Tip & How-To about Computers & Internet
How to reset or remove BIOS password
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.
Manufacturer Backdoor BIOS Password
Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI, IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing.
Reset the jumper that holds the password
Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.
Removing the CMOS Battery to reset the BIOS to default
Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now.
Using third party software utility to reset BIOS password
To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website http://www.hirensbootcd.org/. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
Computers & Internet Logo
how do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
Mar 13, 2011 | Lenovo IdeaCentre A310 Laptop
hello : my problem is i have laptop acer model 5230z : i cant access to the bios becuas is encrypted in passwoed and i try all way that found in web put is no result thank you i hope be help me
Please let me know whether this works or not.
Dec 26, 2010 | Computers & Internet
Tecra , laptop bios password needs to be reset.
mera laptop
think pad r40e
bios pass word
my bhool gaya
pls mere ku help karo
Feb 17, 2010 | Toshiba Computers & Internet
how do you remove the bios password from a dell inspiron 6000 My aunt died and she didn't leave the password behind.
open the rear door on the laptop remove the RAM and locate the 2 pins or Bars in the well where the RAM was.Take a paper clip and short the 2 pins adn then replace the RAM close the door and restart unit.That's it!
Please rate our help to keep the service online++++Thanhks for using FIXYA
Sep 21, 2009 | Dell Computers & Internet
my acer 9500 won't perform a recovery because it is having trouble finding the ghosterr.txt. when trying to change the location it cuts off/shuts down. i cannot otherwise log on to my computer at all. I cannot access my bios because it is asking for a password that I do not have.
Somehow, somebody has manually placed admin password for your bios. Thats the only way it can be done. Try this
Introduction to BIOS Passwords The best method to reset a BIOS password depends on what BIOS the computer has. Common BIOS's include AMI, Award, IBM and Phoenix. Numerous other BIOS's do exist, but these are the most common.
if (!window.netshel_ord) { netshel_ord=Math.random()*10000000000000000; } if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++;
Some BIOS's allow you to require a password be entered before the system will boot. Some BIOS's allow you to require a password to be entered before the BIOS setup may be accessed.
The general categories of solutions to reset a BIOS password are:
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
Using a Backdoor BIOS Password Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
The BIOS password can be reset on any system. Some systems are easy, others are more difficult. Any BIOS password can be reset with sufficient time, money and effort.
Dec 04, 2008 | Computers & Internet
85,069 people viewed this tip
David Payne
David Payne
