Tip & How-To about Pool & Spa
Re furbushing / Repairing a cracked above ground spa
Unfortunately, there are only a few ways to treat the cracks once they have occurred in the shell of the spa. Most repairs offered by "do-it-yourself" products are temporary and will only lead to additional frustration.
This is where years of experience can help out!
Spas are usually molded as a compete unit and then the jets are either cored into the completed shell or are part of the moulding process. Either way, the majority of all acrylic or above ground spas are a single piece.
What this means, is that in order to make a "solid" repair, you will need to treat the entire shell interior.
One of the first real repairs we learned about that is not only affordable, but fairly consistent came from a boat/jet ski repair shop. I had a set of jet skis in the shop and one of them was really damaged. The repair tech had to cut out an entire side of the ski and rebuild it. When complete, you would never know that anything happened!
A lot of these businesses have mobile repair technicians who will actually do the repairs on the spot and are already familiar with various resins, polymers and color matching. The are also great at improvising the repair as they go, because rarely does damage to a boat or ski be consistent with other repairs.
Be sure to ask about the cracks. Cracks usually occur because of shrinkage and if they can separate the areas that are shrinking/have shrunk and then rebuild these areas, you probably won't have a problem again.
We have made similar repair to more than 500 spas and have had issues with less than 1% of the repairs failing. Pretty good odds, if you ask me!
If you are unable to find a boat/jet ski repair guy, you may trying looking under bathtub refinishing. A lot of bath tub refinishing technicians are familiar with working with fiberglass and custom working as you go.
In order to extend the life of the interior of your shell, you should be diligent in cleaning the spa a couple of times a year. Most pool supply stores have a citrus cleaner that works great at cutting through the body oils, lotions and other that may become attached to the spa.
If your fiberglass is starting to feel a bit worn, find out about we sanding and sealing, this will ensure that your spa lasts you many, many years!
Your feedback on thisr is appreciated!
Brian Morris, The Ugyl Pool Guy
www.WeFixUglyPools.com
Pool & Spa Logo
screen is cracked
The only way to repair this problem is to replace the screen/display unfortunately the price of the screen is so expensive that repair is not financially feasible. I am television technician for a 37 years now still active sorry for the bad news if you list the television on craigslist list are eBay you may get offers and also check with shop Jimmy on Internet they may buy your plasma Ron
May 14, 2012 | Samsung 50 in. Plasma TV
Hello the screen on my sharper image literati is cracked. Is there a way I can fix it?
Unfortunately once LCD screens crack, there isn't any way to fix them on your own. I'm guessing that around the crack, there is black liquid inside of the screen. Once the screen cracks, you either need to send it in to get repaired which is probably decently expensive. You can try bringing it back to the store you bought it at and seeing if they can do anything to help you out. I hope this helps! Good luck. Please rate my solution!
- Frankie
May 06, 2011 | Sharper Image Literati Reader 16375680042...
I have a salt water pool and after 3 months it is developing black spots and lines on the bottom and progressing up the sides............I suspect this is an algae..........What would be the remedy for this
Drain the pool get in and TOTALLY scrub all of the fungus & algae off with bleach, (Or it WILL come back quicker) then treat areas with algae killer, and then rinse out all gunk, clean spotlessly, and then refill, and from then on, make sure you use a commercial algae preventative, also up the refresh rate of water exchange.
Aug 11, 2010 | Intex Pool & Spa
squealing bearing
Thank you for posting your question here on Fixya.com.
The seal would be cheap assurance since it is likely what caused the bearing to fail in the first place. The impeller only needs to be replaced if it is cracked in such a way that the seal can not properly seat and prevent water from leaking. Generally speaking, it does not have to be replaced. You can get the bearings and seal from a local electric motor repair shop or pool store that offers repair services.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | A O Smith Motors A O Smith 1hp 115/230v Ur...
223 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
