Tip & How-To about Computers & Internet
Power Consumption by CRT monitors
Frequent PC users especially desktop PC's with CRT monitors has to be very careful in using the CRT monitors as that consumes more power than other types of monitors in market.
Recent research has found the CRT monitors to be consuming 60-80 watts of power for a normal 15 inch monitor compared to 25-35 watts for LCD. The power consumption is almost double in CRT's. If you consider 17-19 inch monitor the power consumption in CRT's might go up to 100-150 watts roughly.
It is advisable for more than 1 CRT monitor users to keep the monitors switched off when not in use so the power consumption is reduced.
Computers & Internet Logo
My 19" Crt Monitor is blurry on windows 7 64bit
The Crt monitor may not have a higher resolution rate that the new ones have for windows 7 64bit, if that is not the case the monitor has a high voltage problem in the flyback transformer, but! it does have a focus adjust, use this with extreme care, may solve problem.
Jul 05, 2012 | Gateway Computers & Internet
how much power does a computer use while in sleep mode?
If your computer is a desktop and using CRT monitor it will consume 60 to 250 watts when being use. But if in standby mode or sleep mode it only uses 1 to 6 watts. A typical CRT 17" monitor is consuming 80 watts and the 17" LCD monitor is consuming 35 watts it defends on the type of unit is being used. hope this may help good day and best regards.
Sep 17, 2011 | Computers & Internet
my screen has shrunk, there is a black frame around it that i cant get rid of. Iv tried changing the resolution and re-starting my computer nothong has helped
Use the OSD (On Screen Display) controls on your monitor to change the "vertical-size' and "horizontal-size" of your picture.
Then, try a different monitor, to see if your monitor is the problem, or if your video-card is the problem.
Apr 05, 2010 | E-Machines eMachines Desktop PC
Before you diagnose the problem, please let me know what it will cost. I am unemployed right now receiving very little from unemployment so I have to be careful. When I turn my computer on (Compaq Presario SR2150NX), my monitor doesn't receive any signal, therefore, it doesn't turn on (it turns on but immediately goes to sleep). There's more.....
if the power light on the computer comes on, but you get no video or the monitor is powered on but goes into sleep mode then your video adapter on the computer is bad. this is a frequent occurance to the default onboard video adapters connected to the motherboard. you must purchase a pci or agp video card and install into the computer and this will solve your problem. hope this helps, please rate me thanks.
Sep 30, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
CRT Computer monitor
Unless you're hell-bent on doing this, I'd say just dump it and get a new, cheap LCD. CRTs are not really user-servicable (as the labels and manuals clearly state.)
If you must, check out this site with a how-to...
http://www.instructables.com/id/How_to_safely_disassemble_a_CRT_monitor/
Good luck. A new LCD would probably be less troublesome and time-consuming.
Dec 27, 2008 | Computers & Internet
181 people viewed this tip
David Payne
David Payne
