Tip & How-To about Washing Machines
417.91702000 Broken dryer belt and felt replacement
To get inside the dryer portion you start by removong the top making a note of where the screws mount makes it easier to put back right later but is no big deal. After removing the top you remove the splashplate and then the controlpanel. The panel has quick connects so the wiring will be no problem. Once the control panel has been removed get the front panel off ad remove the drum.
IThese dryers comewith 2 different styles of glides. The drum mounted version and the front panel mounted versions. The glide kit comes with glue also. I have a page which features videos and more on frigidaire dryers. HERE
Laundry center service manual
Washing Machines Logo
how do i replce the belt in a g.e dryer model#dbxr300gfows
You start by unplugging the machine and it is much easier if you sit it on a work table or tailgate. Have a vacuum cleaner ready. To get inside the dryer yo open the door and look under the top lip for screws. Remove them screws so that the top can be lifted up. Once you get the top up you can remove 2 screws that hold the front onto the frame and remove the front. You will need a phillips screw driver. Make a note of how the lid switch connects to the harness as that can be tricky to get back right. Once you get the front off their is barely any room to reach in and move the idler to the right and place it on a notch on the motor mount to stay put so you can get the drum out. Once the drum is out you can remove all of the lint from indie the dryer and the back side of the drum. Place the new belt rib side down and use it to assist you in getting the drum back inside the machine. Loope the belt under the motor pulley and over top of idler and release idler from the notch. Tension keeps it in place. Turn the drum manually to make sure the idler does not jump the track and is NOT twisted. A twisted belt will be destroyed once the machine is fired up. Here is my crappy cell phone video;
Feb 28, 2014 | Dryers
Dryer drum or rollers or bearings are squeaking on my Kenmore 970-C69042-00 clothes dryer. How do I best trouble-shoot and repair it?
Instructions
    • 1 Turn off the gas to a gas dryer or unplug an electric one. Move the dryer from its position at least 3 feet from the wall. This will give you room to work. Pulling the dryer out into an even more open space may make this easier.
    • 2 Push the putty knife in between the top and main body of the dryer on the front of the dryer. Slide the putty knife near the corner closest to you. Push the knife and pull up to release the pins that hold the top onto the body.
    • 3 Lift the top off the body using a screwdriver as a lever.
    • 4 Label the wires that are connected to the front of the dryer. Make note of which wire goes where. Unclip the wires from the clip that holds them, remove the wires and place them to the side. You will be reattaching these wires later. Be sure to mark them so that you can place them back in order later.
    • 5 Remove the screws that hold the fount of the dryer onto the rest of it. There should be four on most models.
    • 6 Pull the front towards you until the drum inside comes loose from its bearing. Slide the front panel up to reveal the pulleys at the bottom of the machine.
    • 7 Grab the idler pulley. It is the one in front of the motor. Move it to the right to disengage the belt. Remove the belt. Do not remove the belt that goes to the drum.
    • 8 Put on your gloves and slide the drum out of the dryer. Be sure to use hand protection as the edges may be sharp.
    • 9 Inspect the two rollers. If they appear damaged, or you find metal dust under them, your rollers need replacing.
    • 10 Remove the plastic clip on the right hand side if the right roller needs replacing. Remove the metal friction plate, metal brace and plastic clip on the left hand side if the left roller needs replacing.
    • 11 Put on the new rollers and reattach the parts you removed.
    • 12 Slide the drum back in and grab the idler pulley. Pull the pulley to the left until the belt is tight.
    • 13 Slide and screw the front into place and reattach the top.
Jan 15, 2013 | Kenmore Dryers
need to replace the heating element - not getting any heat in the dryer - do you have instructions?
The problem may NOT be the heating element. Although, a likely cause, if the dryer runs, but does not heat, you could have several other factors, that can cause the same problem. The following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three sites also have helpful exploded view diagrams to assist you in parts location/identification. The heating circuitry is listed under the "Bulkhead" heading.
If this is a Kenmore front loader, the heating circuits are accessed by removing the lower toe panel under the door. The panel comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off.
NOTE: You can prop the two front feet of the applaince up for better access to the screws. A 2x4 works well. Make sure the appliance is UNPLUGGED before servicing anything inside the dryer cabinet. Dangerous voltage is still present inside a dryer even with the unit turned off.
If you need better access to get to the dryer heating circuits you will have to perform the following steps:
1. UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even when it is turned off.
2. Open the door and remove the lint screen. IMPORTANT: You will not be able to remove the air blower cover with the lint screen in place.
3. Disconnect the auto dry sensor plug (usually yellow wires with a white plug to the right of the blower assembly) and any ground wires that may be connected to the front panel.
4. Remove the air blower cover by locating and removing the mounting screws.
NOTE: This is a good time to clean the blower fan housing, squirrel cage motor and dryer interior cabinet.
5. Remove the top panel of the dryer by locating and removing the screws holding the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then come off.
6. Locate the two screws that hold the operator console in place. There should be one on each side under the top panel. Remove the screws and carefully lift the panel straight up.
NOTE: You do not need to disconnect the ribbon cables. Carefully lay the console across the top of the dryer out of the way.
7. Disconnect the door switch connector plug and remove the dryer front panel by locating the four screws that hold it in place. Loosen the two screws along the bottom of the panel and leave in place. Remove the top two screws and lift up and turn the whole front panel slightly counter-clockwise to release the drum supports from the dryer drum.
NOTE: Make sure the dryer door is closed when removing the front panel to avoid damaging the door hinges.
8. Remove the dryer drum. Reach in behind the air blower with both hands and pull the idler pulley to the right with your right hand to release the tension and remove the dryer belt.
NOTE: To reinstall the belt later, follow the same steps above for releasing the tension of the idler pulley. Then, with your left hand loop the belt over the drive motor pulley. Release the idler pulley making sure the belt rests on the drive motor pulley. You should feel the belt tighten with tension.If you need further clarification on how to properly route the dryer belt you can go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagram K.
9. With the drum removed, the heating compoents can easily be accessed. The TCO and Hi-Limit Thermostat is located on the outside of the heater box on the left hand side. The TCO is located at the back of the dryer, while the Hi-Limit Thermostat is located adjacent to the heating element terminals.
10. The entire heating assembly is removed by disconnecting all the components leads, followed by loosening the heater box mounting screw. With everything disconnected, the entire box and components will come free and lift out of the dryer.
11. Make sure you take components measurements disconnected from the circuit to ensure accuracy. There are a couple of mounting screws on the side of the heater box that holds the heating element in place. With the screws removed, the heating element will slide out of the box.
12. Replace any defective components and reinstall heater box. Make sure you properly label all wiring to ensure they are reinstalled correctly.
13. Reinstall the front panel by turning it slightly counter-clockwise and aligning the front drum supports under the front of the drum. Once the supports are under the drum, turn the front panel clockwise and lift up, placing it on the bottom two screws. Reinstall and tighten the top two screws.
14. Reinstall the door switch connector plug and reinstall the operator console. Use caution not to put too much stress on the ribbon cables.
15. Reinstall dryer top panel.
16. Reinstall air blower cover and reconnect the auto dry sensor and ground wire.
17. Reinstall toe panel by inserting the top portion first and pushing up. Push lower portion of the panel in place and reinstall screws.
I know this may seem like a lot, but its actually fairly simple if you follow the steps provided. Read through everything before attempting any repairs. If you have any questions, please let me know. I hope this helps you.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
4,316 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
