Tip & How-To about Computers & Internet
Installing Windows XP using a USB Flash drive.
Removable flash memory sticks are pretty much one of the most handy little pieces of technology to come along in the last couple of years. They come in various shapes and their storage size can range from a measly 128 MB to a whopping 32 GB. And you're not restricted by what you are able to put onto these devices either. Which got me thinking today. I am regularly installing fresh copies of Windows onto new built PCs, so I look for any way to increase the speed at which my work gets done without compromising quality, of course.
So I thought, with the speed of flash drives today, it could be possible to install Windows XP onto those PCs in a much faster time than with optical media (CD/DVD). Plus with all the motherboards I use, I always make sure that the motherboards support booting from USB as it's a very handy feature. So I decided to look into the various guides that can be found on the Internet. Originally meant for the EEEPC, I found a guide that I was able to understand. Because of the way it was written it took me longer than 10 minutes to understand the whole procedure and I'm sure the average geek would be completely confused before they had reached the second line, simply because of the total lack of explanation on the part of the guide's creator for those who do not usually do this kind of thing.
Anyway, as with all guides, you have to realize that there is a certain amount of risk involved with the procedures I am about to give you details for and that you use this guide at your own risk; I will not be held accountable for any damages done to your hardware if something should go wrong. It will involve the use of the command prompt and it has the possibility of damaging your flash drive. Although I believe that the chances of that happening are quite slim, there is always the possibility, so I thought I would warn you before you decide if you're going to use my guide. Now with the pleasantries out of the way, let's get down to business. There is some preparation needed before we can start this procedure. First off you need to make sure you have the following available to you:
1. An unmodified, legal copy of Windows XP Home or XP Professional
2. USB memory stick (2 GB recommended - 1 GB minimum)
3. A motherboard that is capable of booting from a USB drive (check your motherboard manual if not sure)
As long as you have all three points above met, then you are ready to start. Just so you know, in this process your USB flash drive will be formatted, so do not use a USB that contains data vital to you. As for a motherboard that is capable of booting from a USB drive, most modern motherboards offer this as a standard feature. If your motherboard is less than two years old, chances are that the motherboard you have supports this feature.
Okay, now we have made sure that your computer is capable of installing XP from a USB disk. The next thing we need to do is to download and extract three tools that are going to help us in this procedure. You can find download links to these files below:
1. USB_Prep8
2. PEtoUSB
3. Bootsect
I suggest you download these files directly to the root of your hard drive. In other words save them to a folder on the same drive that contains your operating system - for most people this will be the C: drive. Once they are all downloaded, go ahead and extract PEtoUSB and USB_Prep8 to separate folders. Once this is done you should take the contents of the PEtoUSB folder and copy them into the USB_Prep8 folder. Once this is done, you should go back to the root of your drive and extract Bootsect to the root of the drive (program files and Windows folder is stored in this area). We do not need to worry about the Bootsect program for now, however that is simply preparation for later. And as another matter of preparation I suggest you insert your Windows XP CD, create a folder on the root of your drive, name it XP, and then copy the contents of your Windows XP CD into that folder as you will need these files soon.
Okay, now that all the preparation is out of the way, we'll start the process. It will take on average about 20-25 minutes to complete this process depending, of course, on the speed of your PC and of the USB stick you are going to be using. I must warn you now that you should NOT close any of the windows generated by the programs I am showing you how to use until you reach the point in this guide when I tell you to do so. This is quite important because, if you happen to close any of the following windows, it is possible that you can screw up the procedure and you will have to start again. With that out of the way, as long as you follow the instructions below, everything will run smoothly.
1. Go into the folder named USB_Prep8 and double-click the following: (usb_prep8.cmd)
2. Make sure you select the newly created command prompt window and click any key to continue
3. A new program is started (PeToUSB). Do not change any of the settings; just click start and let it run
4. Once PeToUSB is finished, DO NOT CLOSE any of the windows the program created
5. Go to your start menu and click run if you're using the classic start menu
6. Enter the following command into your run window: (CMD)]
7. Once you have run that command, a new window will appear with the words command prompt
8. Provided that you have used the file setup I suggested, input the following: ( cd \bootsect )
9. Type in the following: ( bootsect /nt52 :R ) Replace R with the drive letter of your USB drive
10. You will see the message (Bootcode was successfully updated on targeted volume) if it worked right
11. You may NOW close all the windows except for the window that was created when you ran USB_Prep8
12. Providing you closed all the right windows, the USB_Prep8 Window will now contain seven options
13. Press 1 on your keyboard - this will bring up a window. Locate your XP folder and highlight it. Click OK
14. Press 2 on your keyboard - the program will ask for a unused drive letter (example: T or Z)
15. Press 3 on your keyboard - the program will ask for your USB Stick drive letter; enter it now.
16. Press 4 on your keyboard to start the USB_Prep8 process
17. The program will ask you if it is OK to format a drive contained in the letter you gave in #14; click yes
18. The program will start to copy the needed files; be patient
19. The program will then ask you if you wish to copy these files to the USB stick; click yes.
20. Finally, once it has finished copying the files, it will ask you if you want to make the stick the preferred boot drive. Click yes, after which it will ask if you wish to un-mount the USB stick. Click yes
And that's all there is to it. The USB flash drive is now ready to install XP to any hardware that is supported by the Windows XP CD. However there are some minor differences to installing Windows XP this way than if you would with an optical drive, which I am going to go into. Of course, as I have said before, the speed at which Windows XP installs is MUCH faster when installing using a USB stick than if you were using an optical drive (CD/DVD). But the speed comes at the price of you needing to pay a little more attention to the install itself. Now from this point on, I am going to assume that your motherboard does in fact support booting from USB and that you have gone into your BIOS and have set the USB flash drive as the first drive to be booted from (make sure the flash drive is connected before you turn power on - it helps). I cannot give a generic answer to where that option is in your BIOS; I suggest you look up in your motherboard's documentation.
Providing it boots from the USB flash drive, you will now be shown two options. One with the words GUI and one with the words Text Mode. Choose the Text Mode option first. Now you will see what you normally would see during a CD install of XP. Just follow the on-screen instructions as always. One note is that, if you need to create a new partition for your new Windows XP installation, once the partition is fully formatted, instantly turn off the PC as the install will need to be restarted so the flash drive can recognize the layout of your partitions correctly. Follow the instructions below:
1. Create a new partition and format it as normal
2. Once the partition is formatted, restart your PC and when the options come up again choose Text Mode
3. Highlight the newly formatted partition, press enter, move down to make no changes, and press enter
Okay, now after that all goes through and the PC restarts, simply chose the GUI option on the menu and let the Windows XP install go along as it would normally do. I must advise that you DO NOT REMOVE the USB stick until you're actually past the setup stage. Once you have just booted into Windows XP for the first time, you can go ahead and remove the USB stick. Congratulations! You have just installed Windows XP without the need for a CD/DVD drive.
  • The benefits of installing from USB are plentiful and, providing you take the time to follow the instructions above, you need never worry about scratching your Windows XP CD again. I hope that the time I spent writing this guide will help you all to decrease the amount of time you spend having to install Windows XP when you have to. Peace!
Computers & Internet Logo
gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
zero bad sector error usb pendrive
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the flash or external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the flash or external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Many people still don't realize this, but flash memory wears out the more you delete and write files to it. How quickly it wears out will depend on the specific flash drive. Like anything, there is a wide range of quality in currently available flash memory-based drives. You can make a rough correlation with the cost/quality of the device (what you pay is what you get), but even that tends to change over time. Depending on usage and quality it could be talking as short as months or as long as several years. In extreme cases of misuse it could lasting as little as a few weeks.
Nov 28, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Memory stick error
hi bubba9
if you are using the handy cam just look at the specs on the manual to determine what memory card is compatible. based on your info it is unlikely that the camera even supports 4gig of memory. You should try the smaller sony memory stick up to 2gb only and it should work. good luck
smeags.
Dec 31, 2007 | Sony Handycam DCR-TRV530 Digital Camcorder
153 people viewed this tip
David Payne
David Payne
