Tip & How-To about Computers & Internet
How To Secure your wireless connection
If I wanted to check if someone using my wireless router to access the internet without my permission, I'd be right in thinking that if I opened my Network Places dialog box and select View Computers workgroup, I am unable to see anything interfere with users? Otherwise, what is the best way to monitor my wireless security? Uninvited Guests will usually be displayed in My Network Places, if the attacker uses the same group name as you. If your router is configured to act as a DHCP server, most of which are computer name if unauthorized appear.
Log on to the router and go to the area where you can change the network settings. Take a look at your router assigns IP addresses via DHCP, which is the default. Explore the list of attached devices, if you do not recognize any of them may be an intruder.
The best way to prevent anyone from connecting to the router without authorization is to use WEP or preferably WPA. Configure your router to use WPA-Personal and WPA2 if possible. Select and enter your password and will only be given to those who need to communicate.
If your router does not support WPA, or you do not use encryption, you can use MAC authentication instead. You must know the MAC address of your Wi-Fi card and enter it into your router. You can use this with the default security for greater protection.
Computers & Internet Logo
Can some one give me a free network pin code for my tmobile sony xperia z1s
Sorry. I think you are asking something what is not possible. Your phone does connect to the provider, with a sim card. it has an unique code and you can't copy it. Your provider does need this information, to bill your usage on the phone network. Without a Sim, no connection to the phone network, because no cell tower will connect you. (No service on the phone)
As soon as you want to work on WiFi, you need a WiFi router close to the phone. The maximum distance a WiFi router can be away is about 100 meters in open air. In a house or building it is much less.
To connect to such a wireless router, you need to have permission from the owner. Because he (most of the time) did setup the router with an identification name and a password. All connections you can see under settings and WiFi, are close to you. The ones you see with a little padlock are protected with a password. The ones without a padlock are open.
To access the internet yourself, you should have an internet connection in your house and a wireless router.
So I'm afraid without a sim or without an open WiFi connection to the internet, no soup for you. Pin codes won't work without any connection.
Sep 09, 2014 | Cell Phones
How to change wifi password on Buffallo AirStation WBR2-G54 router
I'm not 100% sure, but I think the password is actually programmed into the bios of the router, so you can't change it...could be wrong. If someone is using your router, they must be aware of your password, remove the password sticker off your router and keep it in a safe place
Nov 24, 2013 | Computers & Internet
how do i make sure nobody else is using my internet without my permission?
You need to set up a network password to keep others from piggy-backing onto your internet connection and to secure others from accessing your data. I can walk you through the process if you give me your router''s manufacturer and model.
Jun 26, 2011 | Computers & Internet
router and internet down
Did they have physical access or was it just wifi access.
If they had physical access it's an easy matter to reset the router back to factory settings.
Use your D-Link manual to rest it back as it was with your ISP settings.
Jun 04, 2010 | D-Link Xtreme N DIR-655 Wireless Router
someone is acsessin my router and useing my internet without my permission i need to change the password but i cant
Reset both password (1) pasword for access router via GUI (2)Wi fi security password WEP or WPA or WAP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on administration and change password .
Then Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 17, 2010 | Belkin Computers & Internet
340 people viewed this tip
David Payne
David Payne
