Tip & How-To about Computers & Internet
How to remove vista and install XP
Hi ALL
Please find the tip.
  1. You must use a full retail or OEM version of XP (not the cd from your old computer) this makes life really easy and can usually be downloaded from the web.
    You must also have a genuine
    XP key, which has not been used on another system (without genuine key you will not get updates and your system will be labeled as using pirated software by Microsoft.
  2. Next you should know or find out the specifications of your system, to do this goto Manufactures website.
  3. The most important step is to find out if your hardisk is using SATA interface (if so you will require the SATA XP drivers and a floppy disk, as this is the only way that XP can install these drivers.)
  4. Install XP via cd rom by booting cdrom at system start (if you cannot do this then you must access your system bios at first boot by pressing F2 or Del keys(or whatever key your system uses) and change the boot option to cdrom as first drive.
    If your system uses
    SATA press F6 when XP prompts "press F6 to install other" at very beginng of XP install and install sata drivers from floppy.
  5. Use our guides to install XPhttp://www.windowsxpprofessional.windowsre...REPAIR%20GUIDES
  6. After install you will have to install your systems other drivers(ie. chipset graphics audio etc) found by reading your system specifications and downloading from your Manufactures website)
  7. AN XP INSTALL IS NOT FOR THE FAINT HEARTED AND WILL REQUIRE A THOROUGH UNDERSTANDING OF YOUR SYSTEM SPECIFICATIONS A FULL RETAIL OR OEM XP DISK AND CORRECT XP DRIVERS.
AKPC_IDS += "901,";
Computers & Internet Logo
I need to do a windows repair but I cannot find my cd. Can I download one and save it to a disk and install it on a different computer
Ask your friends to borrow either a "retail" Windows XP Home Edition CD-ROM (bought when XP was available in retail stores) or an "OEM" (Original Equipment Manufacturer) version. The OEM version was used by Microsoft-licensed "system-builders" (small computer-stores that assemble computers from the individual components, and then install this "generic" version of Windows).
If you have the "genuine Windows" decal on the side of your desktop, use that 25-character product-key and the "borrowed" CD-ROM to reinstall Windows.
Nov 18, 2010 | Dell Microsoft Windows XP Home Edition
reinstalling xp will not take my product key
If you are reinstalling Windows XP from a NON-DELL disc, and trying to use the Dell OEM product key, it will not work.
OEM versions of Windows have a modified precopy2.cab and a retail version of XP will not validate the OED product key from the chassis. This is because the OEM media for Dell has a precopy2.cab that pre-loads the product key when the system is BOOTED to the OEM media (It also pre-activates the OS)
Your choices at the point are:
  1. Re-install the OS from a Dell OEM CD (They can be purchased on EBay for around $20, and only work on Dell Systems)
  2. Purchase a valid Retail Key from Microsoft
Feb 20, 2010 | Dell Inspiron 8000, 8100, 8200 Series...
How to uninstall Windows Vista
You must also have a genuine XP key, which has not been used on another system.
If your system uses SATA press F6 when XP prompts “press F6 to install other” at very beginng of XP install and install sata drivers from floppy.
Jun 12, 2009 | Microsoft Windows Vista Home Premium SP1...
OEM vs. RETAIL OS CD
Hey Hicomp! Generally retail packaged software is designed to be sold in retail stores and as such comes with a lot of literature, extra paperwork, CD's, and usually tech support for the program you're purchasing. OEM packaged software is the same software just without the retail packaging, extra paperwork, and no tech support usually.
Mar 08, 2009 | Microsoft Windows XP Professional
197 people viewed this tip
David Payne
David Payne
