Tip & How-To about Computers & Internet
To delete the information automatic learning has collected
  1. Open Pen and Touch by tapping the Start button , and then tapping Control Panel. In the search box, type pen and touch, and then, in the list of results, tap Pen and Touch.
  2. Note
  3. You won't see Pen and Touch if you aren't using a Tablet PC or a computer with a touchscreen.
  4. On the Handwriting tab, tap Don't use automatic learning, and delete any previously collected data, and then tap OK.
  5. In the Delete Collected Data dialog box, tap Delete Data.
Computers & Internet Logo
950cartridge will not install
  1. On the printer control panel, touch (right arrow), and then touch (Setup).
  2. Select (Preferences), and then select (Cartridge Chip Information).
  3. Touch (OK) to turn off the usage information collection.
HP 950XL/951XL Cartridge Protection
On the printer:
HP OfficeJet Pro 8600
  3. Touch (OK) to turn off usage information collection.
HP OfficeJet Pro 8100
  1. On the printer control panel, press and hold the (Wireless) and (Resume) buttons.
  2. The ink supply icons will blink four times.
  3. Press and hold the (Wireless) and (Resume) buttons again to turn usage information collection back on.
Next on the computer: (See image below - available on website only.)
The HP Officejet 8100 and 8600 has a "cartridge protection" feature. In the toolbox there is a tab named "HP Cartridge Protection", where you can choose if you want to enable or disable this function. The default setting here is "enable" which results in the cartridges only working in this particular printer. If you install the cartridges treated with this "protection" feature in another printer, they will not work and a message pops up.
Printer Warranty
  • Use of remanufactured or compatible cartridges does not void your warranty as stated by the MAGNUSON-MOSS WARRANTY IMPROVEMENT ACT, United States Code Annotated Title 15 Commerce Trade Chapter 50, Consumer Product Warranties 15 Sections 2302.
Aug 24, 2015 | HP Office Equipment & Supplies
How do I check my Dell 7000Touch Screen Troubleshoot
Run the troubleshooter. Follow these steps:
a. Press the 'Windows + W' key on the keyboard.
b. Type troubleshooter in the search box and then press enter.
c. Click hardware and sound and run the Hardware and Devices Troubleshooter.
d. Follow the On screen instructions.
In addition, Follow the mentioned steps to enable Touch tab if it is disabled:
a. Navigate to Start screen. In the Start screen, click on
b. Control Panel tile.
c. In control panel Window, Scroll down and tap on the "More Settings" option.
d. Old Control Panel window will open.
e. Next, go to Hardware and Sound and after that click on Pen and
f. Touch option. Pen and Touch window will open.
g. Now, in the Pen and Touch window, navigate to Touch tab option. Check whether Use your finger as an input device box is unchecked, if so uncheck it. Then press
h. Apply and then OK.
Jun 12, 2014 | Dell Inspiron One 19 All-in-One Desktop PC...
ther are save photo album i want to delete it but it cant
To delete synced photos and videos
  1. In iTunes, select the device icon in the Devices list on the left. Click the Photos tab in the resulting window.
  2. Choose "Sync photos from."
    • On a Mac, choose iPhoto or Aperture from the pop-up menu.
    • On a Windows PC, choose Photoshop Album or Photoshop Elements from the pop-up menu.
  3. Choose "Selected albums" and deselect the albums or collections you want to delete.
  4. Click Apply.
To delete Camera Roll photos and videos
There are two methods to delete items from the Camera Roll:
or
  • Delete photos and videos from your device manually. Open the Photos application, open the Camera Roll, tap the Action button, tap each photo to select it, and tap the Delete button.
Oct 15, 2013 | Apple iPod touch
hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
when I use my pen to click on my nintendo DS screen,it touches or selects somewhere else on the screen so I can't play my games properly.
Might need to re-calibrate your screen. From Nintendo's site.
1 Remove all games from the DS.
2 Turn the system on.
3 Press the A Button when the "Touch the Touch Screen to continue" message appears.
4 When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
5 Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
6 Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
* You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
* If the above steps did not help, there is a problem with the system and it will need to be repaired.
7 When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
8 Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Jul 31, 2008 | Video Game Consoles & Games
212 people viewed this tip
David Payne
David Payne
