Tip & How-To about Computers & Internet
How to Preserve your Battery
Make sure you only charge it whenever the battery level is like 20%. When battery is fully charged, remove plug from main source. Do not watch movies too much while running on battery.
This will help prolong your battery life
Computers & Internet Logo
charging indicator starts blinking when i watch movie for more than one hour on battery
A laptop won't last long without being charge, a fully charge battery should last about 1hr 30mins so charge the battery while your watching a movie next time.
Mar 29, 2012 | Computers & Internet
I have to reset the country date time etc every time i turn my camera on, i have tried going through menu and reset but this hasn't solved the problem. Please help
There is a built in battery that can keep the time date etc. info for 20 something hrs. without any other source of power. If your camera has a charged battery, is plugged into an active USB or powered by an adapter and you shut it off and then immediately turn it back on again, what happens? If the clock needs to be reset are you sure that you have completed setting the time. After adjusting all the settings you hit set. Most likely it seems that your internal battery is bad. It should charge when the camera is being powered by the main battery.When you say every time you turn it on I'm not sure what that means. If you turn the camera off and remove the battery for more then 30 hrs. it will have to be reset. If that is the case you need to leave a fully charged battery in long enough to charge the built in battery. If the built in battery is bad you will need to find out if it can be replaced.
Aug 04, 2010 | Casio Exilim EX-Z750 Digital Camera
Battery won't charge
a car battery? how eactly do you do that?
May 22, 2009 | HP Hewlett Packard Pavilion DV9500T 17"...
Power source.
Well I am not a technical person, but i imagine it should be possible to use all such products while they are charging.
Aug 12, 2008 | Philips PET702 Portable DVD Player
204 people viewed this tip
David Payne
David Payne
