Tip & How-To about Computers & Internet
How to change the serial number used in Windows XP.
Open Start/Run... and type the command:
regedit and click "OK" (or press ENTER).
Go to HKey_Local_Machine\Software\Microsoft\WindowsNT\Current Version\WPAEvents,
on the right double click on "oobetimer" and change at least one digit of this value to deactivate windows.
Click "OK" and close the Registry Editor.
%systemroot%\system32\oobe\msoobe.exe /a and click "OK" (or press ENTER).
This will bring up the "Activate Windows" window.
Check the option for "Yes, I want to telephone a customer service representative to activate Windows" and click "Next"
Then click "Change Product Key" (don
Computers & Internet Logo
My computer is not recognizing the player. What can I do?
HI,
According to the information, I recommend you follow these steps to resolve this issue:
Step 1: Remove Hidden Devices
1. Click Start. Click Run. Type cmd and press OK.
2. Type "set DEVMGR_SHOW_DETAILS=1" (without quotation marks) and press Enter.
3. Type "set DEVMGR_SHOW_NONPRESENT_DEVICES=1" (without quotation marks) and Press Enter.
4. Type "start devmgmt.msc" (without quotation marks) and click press Enter.
5. Click View. Click Show hidden devices.
6. Click "+" to expand Imaging devices, Unknown devices and USB devices.
7. Are there any digital camera devices and unknown devices (including grayed out devices)? If so, please right click it and click Uninstall.
Step 2: Remove all oem*.inf files
1. Click start and click run then under the run line type in the command "cmd" (without the quotation marks)
2. In the command line, type in the following (without the quotes) and press enter after each command:
"cd \windows\inf"
"ren infcache.1 *.old"
"ren oem*.inf *.old"
"del C:\windows\setupapi.log"
"exit"
Step 3: Removing all entries under HKEY_LOCAL_MACHINE/Enum/USB that start with VID
Removing the VID entries from the registry will cause them to be redetected at restart.
CAUTION: If you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
1. Click Start and click Run. Type regedit and click OK. The Registry Editor window will open.
2. Go to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB.
3. Highlight and delete all the VID_.... entries.
Permissions may be set allowing the deletion of the VID_ entries by following the steps below:
a) Right-click the key to be deleted, and then click Permissions. The VID_... Permissions window will open.
b) With Everyone highlighted in the Group or User name section, select Full Control in the Permissions section.
c) Click Apply, and then click OK.
4. Turn off the computer and reboot after that try to connect the player.
Thanks
Sachidanand
Jun 17, 2010 | Apple iPod shuffle Second Gen. Silver (1...
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
cd drive not detected
Lets do this.
1. Close all programs
2.Click on Start, Run, and type REGEDIT and press Enter.
3.click HKEY LOCAL MACHINE - SYSTEM - Current control set - control - class - select {4D36E965-E325-11CE-BFC1-08002BE10318} - on the right hand side you'll find upper filters and lower filters entries - right click and delete both(Upper and lower filters) - restart your computer and hope this works for you,
Awaiting response.
Thanks..
Sep 08, 2009 | Acer Aspireā„¢ T180 PC Desktop
local drives not opening
Try the following...
From the start menu click "Run".
Type "cmd" and press Enter, this will launch the command line editor.
Type "x:" without quotes, where "x" is the drive you cannot open in explorer.
Type "attrib -r -s -h autorun.inf" and press Enter.
Type "del autorun.inf" and press Enter
Repeat this for each local drive that will not open.
Restart your PC.
Hope that helps!
Feb 03, 2009 | Compaq Presario Notebook
Two days ago I turned my computer on and where my sidebar gadgets should be there were black squares and rectangles. My clock was square with a black face and not working. I tried installing different gadgets with the same results. I bought this computer on 7/31/08
Hello Donpd,
I have the solution to resolve the issue.
Perform the steps as provided below:
1. Close windows Sidebar. Right click on the Windows Sidebar notification area icon and click Exit.
2. Open the Start menu and click All Programs, then click Accessories. Right click on Command Prompt and click Run as administrator.
3. In the command prompt, type "regsvr32 msxml3.dll" without quotes and press Enter. Then click Ok.
4. In the command prompt, type "regsvr32 scrrun.dll" without quotes and press Enter. Then click Ok.
5. In the command prompt, type "regsvr32 jscript.dll" without quotes and press Enter. Then click Ok.
6. Turn Windows Sidebar back on.Check to see if Windows Sidebar is displaying correctly now.
Sep 10, 2008 | Computers & Internet
656 people viewed this tip
David Payne
David Payne
