Tip & How-To about Computers & Internet
Internet Quick fix!
Here is a quick fix that also seems to speed navigation up some.
Just for safety create a copy of the file before making changes.
Go to
C:\windows\system32\drivers\etc\ (Windows XP)
Open the host with notepad.
remove all entries bellow
127.0.0.1 localhost
then save and close.
Computers & Internet Logo
How to Use the Command Line Interface?
The command-line interface was used decades before the graphical user interface (GUI). However, its speed and versatility still make it a popular choice today.
FOLLOW THIS STEPS
  1. Pick your command-line interface. MS-DOS, Powershell and Bash are popular.
  2. Learn how to navigate directories and list contents.
  3. Learn how to manage files and directories. Creating, copying, moving, renaming, deleting. Midnight Commander is a command-line Orthodox File Manager.
  4. Learn how to edit files with text editors.
  5. Learn how to search. Grep is popular and powerful tool for searching for expressions within files.
  6. Learn how to network. You can connect to the internet via the command-line.
  7. Learn how to use multimedia software from the command-line.
  8. Learn how to manage users. Adding, removing, changing passwords can be done via the command-line.
Oct 19, 2016 | Computers & Internet
how to create my own themes
· Navigate to ownskin.com. Click "Sign Up" to create an account.
· Click the "Create Now!" link in the top menu (right-hand side) and then click the "Make a Theme" button. Select "Phone Model" by clicking on the "N70."
· Click "Professional Theme Creator" (advanced settings) or "Express Theme Creator" (quickly create theme -- however unable to edit saved them). Create "Idle Background" by clicking the "Browse" button, locating an image, and clicking "Upload." Crop the image to your liking and click "Done." Create "Active Background" by clicking the "Browse" button, locating an image, and clicking "Upload." You can choose to use the same image as used in the "Active Background" or upload a new image.
· Click the "Advance Settings" button to add color filters, text color, clock style, battery icon, application icon, and more. Click "Create My Skin Now" to create theme. Give your theme a name, description, and choose whether you want to share it (public) or keep it for personal use (private). Click "Save Skin."
· Click "Download to PC" to copy theme to your computer. Connect phone to computer via USB cable and copy the theme file into the "Media Files" and then "Theme" folder. To download the theme directly on your Nokia N70, click the "WAP Download" link and copy the "OSKey Code." From your cell phone, navigate to w.ownskin.com and enter the "OSKey Code" to download theme. Open "Themes" folder from control panel on phone, select theme, and click "Apply."
Thanks for rating
good luck
Jan 27, 2011 | Nokia N70 Cellular Phone
i have bought myself a new computer with windows 7. i have tried to install my most favourite game, il2 1946. i cannot get it to install... what is wrong with it?
For complete instructions on how to get it working see http://forums.ubi.com/showthread.php...-with-win7-FIX , however the quick version is:
  • Insert disk
  • Do NOT use the autoplay installer. Navigate the disk, find and run a file called "a.exe". The game installation will start.
  • When the installer starts, choose "custom install" and make sure the installation folder is NOT inside C:\Program Files\ or C:\Program Files (x86). Windows is over protective of these folders and wont let IL2 (or you) change any game settings. Simplest is to create a folder called C:\Games and install it there.
  • Start the game. If you get a Securom error, go to https://support.securom.com/analysis.php and follow the instructions.
Or you can just buy GOG download version that has no copy protection and is compatible all the way to Windows 8.
Nov 19, 2010 | Ubi Soft IL-2 1946 PC
I cannot find the iso file on my computer
Dear Sir/Madam,
It does not change ISO file. ISO file is to create with software available at http://www.poweriso.com/
Once you have used this software to create ISO. If u have using nero they has also a option for creating ISO file. Check settings.....
Thanks
Good luck
"Don't Forget to rate the Solution"
Jun 09, 2008 | Computers & Internet
Can't Copy Files onto USB Drive
You should have no isssue moving or copying files from a flash drive to your hard drive, unless there is some very unusual type of security placed on them. It sounds like you should make sure you have the proper windows open to drag and drop in Explorer or My Computer windows. I personally find it easier to drag and drop using My Computer. Open My Computer, and navigate to the folder where you want to place the pictures. (There is a quick link to My Documents on the left sidebar.) Once there, leave that window open. Then open a new My Computer window, and navigate to the flash drive, where the files should be listed or displayed. Select the file(s) you want to move, and drag them over to the first window, which is still open to your desired destination. This should solve it - thanks for rating FixYa!
Apr 30, 2008 | Electronics - Others
175 people viewed this tip
David Payne
David Payne
