Tip & How-To about Cell Phones
How to get easily your SIM card passwords (PIN & PUK) on Cellular phones
As we know each SIM card has PIN and PUK. They are provided and underservice provider control. In frank, it is not too hard to get your SIM unlockedby get it unlocked through 3rd parties or service provider help through call center or customer care line. But there iseasier way to get back your SIM unlocked without wasting your time and bucks.What thing should to do then? If you have 2 or more cellular phones, just saveall your SIM passwords in all cellular phones. You can request the SIM passwords on your service provider call center for free. You can save it as contacts/name, message template etc. ( what ever you want and applicable ) in your phones. So that if one SIM locked out you can get solution in other phones quickly .You can also use your family phones, closed friend phones etc. as back up in same way.
Cell Phones Logo
need a puk pin code
The PUK code is not related to the handset.
It is rather associated with your SIM card.
When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. If your operator failed to provide this PIN-PUK code to you, perhaps, you would have to get it from your operator. Try calling your customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
May 01, 2011 | Samsung Cell Phones
its frozen on and says PUK is blocked pls contact your provider and and i didnt know i had a PUK code so i dont know what it is
A PUK code is a Pin Unlock Key code. A PUK code is required to unlock a SIM. Please contact your service provider for PUK code because only they can provide you a PUK code.
Mar 13, 2011 | Cell Phones
it asks for a 4 diget PUK code, a new pin code then a conform pin code but it just doesn't work.
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Mar 11, 2011 | Cell Phones
i jus locked my lg vu i dont know what the PUK code is
The PUK code is not related to the handset. It is associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Mar 05, 2011 | LG Cell Phones
requir puk code my cell no is 09724300600
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the puk code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Mar 17, 2009 | Nokia N70 Cellular Phone
140 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
