Tip & How-To about Cell Phones
Jailbreak and Unlock Your iPhone 3G Using RedSn0w (Windows) [4.2.1]
These are instructions on how to jailbreak your iPhone 3G on the 4.2.1 firmware using RedSn0w for Windows.
Step One
Create a folder on your desktop called Pwnage
Download RedSn0w from here and place it in the Pwnage folder. Likewise, download the latest 4.2.1 firmware from below and place it in the same folder.
4.2.1 (3G): iPhone1,2_4.2.1_8C148_Restore.ipsw
Extract the redsn0w executable from the RedSn0w zip file into the same folder.
Step Two
Connect your iPhone to the computer and launch iTunes.
Select your iPhone from the list of devices on the left. Now hold down Shift and click the Restore button. Restore is preferred as it won't create any wasted space on your iPhone.
Navigate to the Pwnage folder on your desktop and select the 4.2.1 firmware ipsw. Click the Choose button to continue.
Step Three
Once iTunes has finished updating your iPhone to the desired firmware open the Pwnage folder on your desktop and launch the redsn0w application from the redsn0w folder we extracted earlier.
Step Four
Once RedSn0w opens click the Browse button
Step Five
Select the 4.2.1 firmware ipsw we placed in the Pwnage folder on our desktop then click Open.
Step Six
Once the firmware has been verified click the Next button to continue.
Step Seven
RedSn0w will now prepare the jailbreak data
Step Eight
From this window you can select the jailbreak options you would like.
Verbose boot displays detailed information on boot of your device and is generally only needed by developers and advanced users.
Make sure Cydia is selected. For this tutorial we will also select Custom boot logo and Custom recovery logo.
When you click to select each custom logo option a dialog window will appear asking you to select the image. Locate the image you would like to use then press the Open button.
*Remember the rules for boot logos are: RGB or Grayscale format with Alpha channel and dimension below 320x480. If you would like to use the iClarified ones they can be found here: Boot Logo, Recovery Logo
Notice that RedSn0w can Enable multitasking, Enable homescreen wallpaper, and Enable battery percentage. If you do not need multitasking we would recommend deselecting it as it makes your iPhone 3G run very slow.
If you read the warning above and you would like to update your baseband to the 06.15 iPad version for unlock then check Install iPad Baseband. Click Yes when prompted to confirm your decision.
Click the Next button to continue
Step Nine
Please plug your iPhone into the computer and make sure its OFF then click the Next button
Step Ten
RedSn0w will now guide you through the steps to get into DFU mode. You can find more help with DFU mode here
Hold down both the Home button and the Power button for 10 seconds.
Release the Power button and continue holding the Home button until RedSn0w detects the device.
Step Eleven
RedSn0w will now downloaded the iPad baseband if needed and your iPhone will reboot
Step Twelve
RedSn0w will then begin uploading the new RAM Disk and Kernel.
Step Thirteen
Once this is complete you will be notified that RedSn0w is done. Click the Finish button. When your iPhone finishes rebooting (5 minutes or so) it will be jailbroken with Cydia on the SpringBoard.
NOTES:
If you have problems with RedSn0w on Windows Vista or Windows 7. Right click the executable and set it to run as administrator in Windows XP compatibility mode.
Cell Phones Logo
how to jailbreak iOS 5.1 using redsn0w on PC
Well, if you are willing to perform iPhone jailbreak in a more simple yet time-saving manner, follow the step by step guide from this website: automaticiphoneunlocker.com
You may unlock any iPhone including 2G, 3G, 3GS, 4 and 4S models. This includes both the older and latest versions under 5.1.1.
Enjoy more freedom with your iPhone!
May 05, 2012 | Apple iPhone Smartphone
How do i jailbreak my iphone 3GS?
I have an iPhone 3 black. I am using RedSn0w jail-breaking tool. It is working good on my iPhone. It is easy to use and safe for work.
Apr 05, 2011 | Cell Phones
Jailbreak iPhone 4.2.1
it is possible to do a untethered jailbreak, but i wont recommend it. Heres an article. Read it carefully: http://www.redmondpie.com/jailbreak-ios-4.2.1-untethered-with-redsn0w-0.9.7b1-how-to-guide/
Jan 10, 2011 | Apple iPhone Smartphone
259 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
