Tip & How-To about Computers & Internet
Speed Up Windows XP in 5 Steps
Most of the times we observe that our system seems to gradually slow down. Here below i am listing five basic and easy steps
that can help you speed up your Windows XP computer.
1. Clear the Prefetch Folder :The Prefetch Folder contains files that keep getting stored on your computer whenever you launch any program or application. Deleting these files clears up space on your system that might have caused the slow down. Here is how you need to go about it.
Click Start..click Run..type Prefetch and click ok. The prefetch folder will open up. Press Ctrl and A together. This highlights the entire contents of the folder. Press the Delete key on the keyboard and confirm the deletion. Once done close the prefetch folder window. Now right click on the recycle bin icon on the desktop and right click and select empty recycle
bin and then confirm the deletion.
2. Disable Startup Items: Certain programs get initiated in the background as soon as your system starts causing the system to slow down. These programs are actually not required on startup but because they get initiated it affects the system performance. Here below i am listing the steps to take care of this issue. Please note this step is very effective and
enhances your system startup speed significantly.
Click Start...click Run...type msconfig and click Ok.
The System Configuration utility window will open.
Click on the Startup tab on the top right. Click on the disable all button. Once done, in the list above, you will see many options with checkboxes. Please check any option that indicates your antivirus program software and internet service provider.
Click Apply and Ok. Please restart the system once.Once the system reboots you will get a message coming up saying "You have used the system configuration utility...." Please check the option below that says" Do not show this message again" and click OK.
3.Clear the Temporary Files Folder: Certain temporary files get created as a cache of our activity on the system. Clearing these files from time to time also improves the system speed. Below are the steps for the same.
Click Start..Click Run...Type %temp% and click Ok.The temporary files folder opens.Press Ctrl and A together. This highlights the entire contents of the folder. Press the Delete key on the keyboard and confirm the deletion. Once done close the folder window. Now right click on the recycle bin icon on the desktop and right click and select empty recycle bin
4.Clear Cookies and Temp Internet Files: As you browse the internet the images of the pages you view get saved on the system occupying space on the system. Clearing these files increases your system performance while on the internet.
Open Internet Explorer. Click on the Tools menu on top right. Click Internet Options. Click on delete button to delete cookies, files and browsing history. Click Apply and Click Ok.
5.Scan our system for infection: Your system might run slow in case its infected with virus, spyware, malware, adware, trojans etc. Here below i am listing a tool that you can download and run on the system Its free of cost and is very effective. It scans your system and cleans up any infection. Click on the below link to download the tool. The link that opens up also has a tutorial on running the tool in case you face any difficulty.
Download Combofix Tool
With the above 5 steps, your system speed should surely get enhanced.
If you find the information shared by me in the above tip useful, please do rate the tip.
All the Best!!!
Computers & Internet Logo
what is a solution to fixing the mass air flow system, with code po121
DTC P0121: Throttle Position (TP) Sensor 1 Performance
Circuit/System Description
The engine control module (ECM) uses the following information to calculate an expected airflow rate:
The throttle position (TP)
The barometric pressure (BARO)
The manifold absolute pressure (MAP)
The intake air temperature (IAT)
The engine RPM
P0121 The predicted air flow and the predicted MAP combined are outside a calibrated range for more than 3 seconds.
Circuit/System Testing
  1. Inspect for the following conditions:
  2. ?€¢
    Vacuum hoses for splits, kinks, and proper connections as shown on Vehicle Emission Control Information label
    Inspect thoroughly for any type of leak or restriction
    Air leaks at throttle body mounting area and intake manifold sealing surfaces
    Throttle body for dirt, debris, and coking--Refer to Throttle Body Cleaning.
  3. Allow the engine to reach operating temperature. Observe the MAP Sensor Voltage parameter with a scan tool. Voltage should be more than 0.8 volt and less than 4 volts.
  4. ?‡'
    If more than 4 volts or less than 0.8 volt, refer to DTC P0106.
  5. Idle the engine. Observe the MAP Sensor kPa parameter with a scan tool. Increase the engine speed slowly and then back to idle. The MAP sensor kPa should change smoothly and gradually as engine speed is increased and returned to idle.
  6. ?‡'
    If the MAP sensor kPa does not change, refer to DTC P0106.
  7. Take a snapshot of the engine data list while performing the actions listed below. The mass air flow (MAF) sensor g/s should change smoothly and gradually as the engine speed is increased and is returned to idle.
  8. ?€¢
    Idle the engine.
    Increase the engine speed slowly to 3,000 RPM, then back to idle.
    Exit from the snapshot and review the data.
    Observe the Mass Air Flow (MAF) Sensor parameter frame by frame with a scan tool. The MAF sensor g/s should change smoothly and gradually as the engine speed is increased and is returned to idle.
    If the MAF sensor g/s does not change smoothly and gradually as the engine speed is increased and is returned to idle, refer to DTC P0101 or P1101.
  9. Inspect the throttle body for the following conditions:
Loose or damaged throttle blade
Broken throttle shaft
Any throttle body damage
If any of these conditions exist, replace the throttle body assembly.
Jun 20, 2015 | 2008 GMC Sierra 1500 2WD
my epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
cant get passed by emission test. No codes are coming up but someone keeps saying evap system Catalytic converter, fuel pump, gas cap. O2 sensor has been replaced . Also eating alot of gas. Engine light keeps coming on Help
You have to do a drive cycle, the fuel tank has to be between 1/4 and 3/4 of a tank of fuel, can not be above or below this fuel level.
To perform an OBDII Driving cycle do the following:
1. Cold Start
In order to be classified as a cold start the engine coolant temperature must be below 50ºC (122ºF) and within 6ºC (11ºF) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle
The engine must be run for two and a half minutes with the air conditioner on maximum and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate
Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate
Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate
Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate
This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Aug 26, 2011 | 2001 Pontiac Grand Am SE
Eratic platter direction and speed changes.
Have you seen this solution (Padster07's), it solved my problem: http://www.fixya.com/support/t477894-vestax_pdx200_platter_keeps_changing
Oct 06, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Gateway MX6447 system fan doesn't come on during normal use; the
On my computer, in Control Panel/Device Manager/System Devices I find five (five!) ACPI Fan devices listed. None of them have any adjustable parameters. However, in regedit I find two settings for each: 1) Slow the processor before increasing fan speed (this is ON), and 2) Increase fan speed before slowing the processor (this is OFF).
So...on my computer I am going to say there is no registry setting to make the fan run all the time...can't say that's also true for yours.
Apr 10, 2017 | Gateway MX6447 Notebook
183 people viewed this tip
David Payne
David Payne
