Tip & How-To about Computers & Internet
How to display Errors found and Repairs made CHKDSK
How to display Errors found and Repairs made by the CHKDSK Command
The Chkdsk command is used to verify the integrity of a file system and is capable of correcting discrepancies in system data files. This command has been with us since DOS days and has been modified by Microsoft as required to meet the requirements of new operating and file systems as they evolved.
If you execute the Chkdsk command from a command prompt without using the F (fix) switch, Chkdsk runs in the read-only mode. As Chkdsk runs its tests on the drive, it displays the results of these tests on the monitor screen and the test results remain there for you to read until you close the CMD box.
However there are several drawbacks to running Chkdsk in the read-only mode, especially on an active NTFS volume (usually C:)
1. Chkdsk cannot make any corrections to the drive while in the read-only mode.
2. If Chkdsk encounters more than minor errors, it will not complete all of its tests.
3. If you are running Chkdsk in the read-only mode on the active partition, Chkdsk frequently reports disk corruption and other file system errors which do not exist. This happens when the system modifies the disk during the Chkdsk testing sequence.
Considering the above, there is little to be gained by running Chkdsk in the read-only mode.
You need to run Chkdsk/F at the command prompt to test the drive and to correct any errors found.. As soon as you make this entry the system responds with:
"The type of file system is NTFS. Cannot lock current drive."
"Chkdsk cannot run because the volume is in use by another process. Would you like this volume to be checked the next time the system restarts? (Y/N)."
After you key in "Y" (followed by enter) and re-boot, the operating system starts to load and you are advised that a disk check has been scheduled and unless you cancel it, Chkdsk/F will start to run in a few seconds. (Actually the file being executed at this time is Autochk.exe). Chkdsk will run through its phases but it only displays the test results on the monitor screen for about 2 seconds before the screen clears and the operating system continues to load!
If problems were found wiith the file system, you will not have time to read any messages regarding what they were or what actions were taken. If corrupted files and/or orphaned files/directories were detected you would most probably like to know about it and other problems found by Chkdsk. So how do you display the errors found and actions taken?
The answer is that since running Chkdsk/F is a system event, the information is recorded in the System Event Log under application events. To read the log, Click on Start, Control Panel, Administrative Tools, Event Viewer and Application. Look for "Winlogon" in the Source column and double click on it. An Event Properties dialog box will open and display the log for you to read..
Yavacotech.
Computers & Internet Logo
what is the solution to "Exception EOleSysError module at 00058E75."
Try this:
Run a CheckDisk:
How to run Chkdsk at the command prompt
(Windows XP)
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
      Windows Vista & Windows 7
      You can launch CHKDSK using two methods (the former being the easiest):
      Graphical Interface:
      Open the Computer option from the start menu, which will display all of the drives available to scan on your PC:
      Then, right click on the drive you wish to scan for errors and select Properties:
      Now click the Tools menu, then Check Now under the error-checking section:
      You have several options within the check disk tool. It is always recommended you leave the "automatically fix file system errors" box checked, as this repairs and problems found. If you want to perform a deeper scan, tick "scan for and attempt recovery of bad sectors". This second option takes longer, but is worth doing if you suspect a drive problem. Once you are configured, click Start:
      If you try to check a disk that is currently in use, you will receive a message asking if you wish to schedule a scan. Accepting this will perform the scan next time you restart your PC:
      Good Luck!
Aug 17, 2012 | Computers & Internet
windows always giving notification bad hard disk
Bad Hard disk means a lot of disk partition is damaged and you will have to do a **** check to see how damaged the disk is for disk check and trying to repair it. the command Chkdsk can repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors. log on with administrator rights and open My Computer then left click and now click down on properties, click on the Tools option and Click Check Now then select both the Automatically fix file system errors and the Scan fro and attempt recovery of bad sectors, click Start and Restart...During Restart allow the scan to take place, it will take some time but it is worth waiting. Another simple way to run the disk check is by entering the command Chkdsk in the command prompt, click start then click Run then type in CMD after the command prompt appears (normally a window with a black classic display) type in the command Chkdsk after check is done enter Chkdsk /f ......(to fix the errors)
Mar 24, 2011 | Computers & Internet
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Jan 01, 2011 | Western Digital My Book Essential Edition...
Why do I need to run Chkdsk utility?
Chkdsk it is command for harddrive disk checking this command run on command prompt. This command is used for recover and fix errors on harddrive. When your computer's harddrive ahs bad sectors or any error it run slow and shutdown or restart suddenely. You can fix this problem with "chkdsk" go to start menu->command prompt then type ni prompt "chkdsk /r" without "" then it ask for press "y" press "y" then restart computer then when it start it will fix and recover errors on harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Oct 03, 2010 | Computers & Internet
169 people viewed this tip
David Payne
David Payne
