Tip & How-To about Refrigerators
Refrigerator is Too Cold and Freezing Food
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
Refrigerators Logo
model number 106.52584202
It should be left still for 24 hours before being turned on after moving it.
May 09, 2014 | Kenmore Side by Side Refrigerator
Fridge is not cooling
I hope this helps.
Good luck.
Nov 28, 2012 | Whirlpool Mastermind
My refrigerator freezes everthing in one day
When the refrigerator side is getting too cold or freezes, this is because the control of the compressor has gone bad in some way...
I hope the above helps.
Regards.
May 13, 2011 | Dometic Refrigerators
Food in the refrigerator department is freezing. I checked the refrigerator temperature setting and it is 46 deg f. I checked the freezer temperature setting and it is 5 deg f. I put a NIST traceble temperature probe in the refrigerator compartment and it is reading 32 deg f. Any thoughts ?
Good luck.
Jan 13, 2011 | Microwave Ovens
freezes refrigerator side
When the refridgerator side is getting too cold this is because the control on the compressor has gone bad in some way...
Many newer model refirdgerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
Check to see if the refigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temerature will not solve your problem very simply.
heatman101
Dec 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
24,261 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
