Tip & How-To about Computers & Internet
How to change a drive letterTo change an existing drive letter on a drive, on a partition, or on a volume, follow these steps: Log on as Administrator or as a member of the Administrators group. Click Start, click Control Panel, and then click Performance and Maintenance. Click Administrative Tools, double-click Computer Management, and then clickDisk Management in the left pane. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths. Click Change. Click Assign the following drive letter if it is not already selected, click the drive letter that you want to use, and then click OK. Click Yes when you are prompted to confirm the drive letter change.The drive letter of the drive, the partition, or the volume that you specified is changed, and the new drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool.
Computers & Internet Logo
hp(cefc-4gp pendrive)get fault.the fault is when i insert my pendrive (removable disk drive appears).when i open it .it will not open.my system get hanged
You can try formating the drive first (as long as you don't have anything on it). If they doesn't work, try giving it a new drive letter. It could just be a conflict.
How to change a drive letter loadTOCNode(2, 'summary'); To change an existing drive letter on a drive, on a partition, or on a volume, follow these steps:
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Change.
  6. Click Assign the following drive letter if it is not already selected, click the drive letter that you want to use, and then click OK.
  7. Click Yes when you are prompted to confirm the drive letter change.
Mar 07, 2011 | Microtoolz PenDrive Autorun
The file on my Seagate FreeAgent Pro 880 gig , wont restore to new formated drive ............ letter have change when reinstaling Windows Xp. I see all the different partition on the Seagate. But the hardrive letter are different Robert Roussel
The Disk Management snap-in is an administrative tool for managing hard disks and the volumes or partitions that they contain. Use the Disk Management snap-in when you want to add, to change, or to remove drive letters on drives, on partitions, or on volumes on your computer's hard disks, CD-ROM drives, and other removable media devices.
Your computer can use up to 26 drive letters, from A through Z. Use drive letters C through Z for hard disk drives. Drive letters A and B are reserved for floppy disk drives. However, if your computer does not have a floppy disk drive, you can assign these letters to removable drives.
Before you modify drive-letter assignments, note the following items:
  • Changing the drive letter of the system volume or the boot volume is not a built-in feature of the Disk Management snap-in.
  • Many MS-DOS-based and Microsoft Windows-based programs refer to specific drive letters for environmental or other variables. If you modify the drive letter, these programs may not function correctly.
How to assign a drive letterTo assign a drive letter to a drive, a partition, or a volume, follow these steps:
    Note If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then clickDisk Management in the left pane.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
The drive letter is assigned to the drive, to the partition, or to the volume that you specified, and then that drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool. Thanks or using FixYa! John
Feb 21, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
how do I change drive letter for e to c on my local drive
  5. Click Change.
Dec 09, 2010 | Computers & Internet
Added a new hard river to my Compaq Presario SR1920NX PC Desktop, and it change the old 'C' drive to 'D'. how can I fix this?
How to assign a drive letter loadTOCNode(2, 'summary'); To assign a drive letter to a drive, a partition, or a volume, follow these steps:
  5. Click Add.
  7. Click OK.
Mar 31, 2010 | HP Compaq Presario SR1920NX PC Desktop
pen does not work on hitashi portege 3500
You have to assign a Drive letterto the pen.
How to assign a drive letter ? (Windows XP)
  5. Click Add.
  7. Click OK.
May 04, 2009 | Computers & Internet
259 people viewed this tip
David Payne
David Payne
