Tip & How-To about Office Equipment & Supplies
Generic Refill cartridges
Please be carefull when buying and installing non original cartridges as this can damage the printers printhead and will cost more to replace than buying the original ink for your printers.
Enjoy!!
(Please remember to vote the answer)
why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
how to remove the ink cartilidge
How do I install a new printhead in my all-in-one printer? To replace the printhead in your all-in-one printer:
  1. Make sure the printer is on.
  2. Lift the printer access door and wait for the carriage to move to the access position.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers:
    • On the printer control panel, press Home.
    • Select Maintenance, then press OK.
    • Select Install Ink Cartridges, then press OK.
      If "Install Ink Cartridges" is not an available selection, upgrade the firmware.
  3. Remove any paper that may be loaded in the printer.
  4. Remove the black and color ink cartridges and set them aside.
  5. Remove the existing printhead:
    • For ESP Series Printers, unlatch the printhead by lifting the latch in the center of the carriage.
    • For 5000 Series Printers, unlatch the printhead by pressing the button in the upper-left corner of the carriage.
  6. Lift the printhead out of the carriage.
  7. Remove the new printhead from its bag.
    CAUTION: Do not touch the copper contacts on the printhead, as this may damage it.
  8. Remove the plastic protective shields.
  9. Place the new printhead into the carriage.
  10. Push firmly against the target label of the printhead until you hear a loud snap.
  11. Insert the color ink cartridge into the printhead and press down until you hear it click into place.
  12. Insert the black ink cartridge into the printhead and press down until you hear it click into place.
  13. Close the printer access door.
    The printer detects the new printhead. Follow the instructions on the LCD to calibrate your printer.
    NOTE: ESP 3 all-in-one printers do not require calibration.
IMPORTANT: Be sure to use KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. You can purchase KODAK Ink Cartridges from the KODAK Store.
Feb 09, 2011 | Kodak ESP5 AllInOne InkJet Printer
have a Kodak all in one 5500...black cartridge went empty, replaced it with a non-Kodak cartridge, now it won't print black...changed back to real Kodak cartridge and problem remains....have cleaned head...
I think the printhead is already defective since you tried using a non kodak ink the big difference is the viscosity of a non kodak ink is diff. w/ the original giving more load to the printhead and making it defective.
you can contact support at
1-800-421-6699
Dec 21, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
162 people viewed this tip
jasbo
jasbo
