Tip & How-To about Cell Phones
Pick where you listen to voicemail
If you have a Bluetooth headset, incoming calls are routed automatically it is not the same when you call up Visual Voicemail. But an audio button on the Visual Voicemail screen you can define how you listen to your message: the handset, the built-in speaker or a Bluetooth headset
Cell Phones Logo
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
I just purchased a White Jabra Stone Bluetooth. I can't seem to find my answer of: CALL I MAKE A CALL FROM THE BLUETOOTH HEADSET ?
It doesn't look like you can initiate a call from the headset, only accept an incoming call. It has invisible controls, which can be quite confusing. They have a visual tour on their website of the functions, however making a call is not included.
http://www.jabra.com/sites/mobile/na-us/products/pages/jabrastone.aspx?tab=QSG#UID10
Mar 05, 2011 | Cell Phones
Can I pick up an incoming phone call by pressing a
You should be able to take the call by pressing the center button on the earpiece.
Dec 01, 2009 | Motorola Mobility Bluetooth Hands Free...
Bluetooth H710 new..mic not working
Go in phone to setting then go to bluetooth and press it then select voice routing incoming hands-free
Aug 25, 2009 | Motorola Mobility H710 Bluetooth Headset
Bluetooth is paired and on but instead of answering calls, send call straight to voicemail.
Is there a visble window setting You may have to change it to be visible to your phone for more than a few minutes. Check your setting on answering or sending all incoming to the answer machine. Press the large face button to answer a call.
http://safemanuals.com/user-guide-instructions-owner-manual/PLANTRONICS/EXPLORER%20220-_E link to playtronics for user manual.
Apr 15, 2009 | Plantronics - Bluetooth Headset Plus Base...
167 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
