Tip & How-To about Computers & Internet
The differences between Apple iPad and laptop
Along with the iPod and the iPhone, the Apple iPad is a new device in the Apple line-up and it takes on the mobile computing market. Probably the biggest competitor of the iPad is the standard laptop.
Form:
Unlike the laptop which opens up to reveal the screen and the keyboard, the iPad is a tablet or slate, which does not have any hinges.
Keyboard:
The major contributor to the design of the iPad is the lack of a physical keyboard that takes up a lot of space. Instead, the iPad has a touch screen that is used for all input needs. A software keyboard can appear on screen and you can use that to type anything you want. But for typing out entire documents, a physical keyboard is still much better than the on-screen keyboard of the iPad.
The use of the application:
A problem with the iPad is the use of applications. Although there are thousands of applications for the iPad, it is nowhere near that to laptops. You also can't install just any application as there is no way to do that outside of the Apple app store; so you can't create your own program on the iPad and run it. Another software problem is the lack of true multi-tasking. This is a limitation imposed by Apple in order to prevent users from running too many applications and bogging down the iPad.
Hardware:Aside from software issues, there are also several hardware limitations to the iPad. First, its battery is built-in to the device and is not user replaceable. This means you can't have spare batteries and you need to look for an outlet every time you run out of charge. You also do not have the option to upgrade any part or even use external storage like memory cards or flash drives. The only way to upgrade the iPad is to get a newer one in case they release one. Although upgrade options for laptops are pretty limited, it is existent.Summary:
The iPad takes the form of a tablet rather than that of the laptop
The iPad lacks a keyboard but has a touch screen while it's the other way around for most laptops
You can't install just any application on an iPad unlike on a laptop
The iPad lacks true multi-tasking present in laptops
The iPad does not have user replaceable batteries unlike laptops
The iPad is not upgradeable unlike laptops
For more information about ipad including ipad books download, you can visit ipad-books-download.com
Computers & Internet Logo
iPhone 5c. How can I restore?
Restore your device
Connect your device to your computer using the cable that came with it.
Select your iPhone, iPad, or iPod when it appears in iTunes.
In the Summary panel, click Restore.
Click Restore again to confirm that you want to restore your device to factory settings and delete all data and content.
Feedback
iPhone 5c - How to Reset Back to Factory Settings - YouTube
z? 5:22 https://www.youtube.com/watch?v=__ujKpff2B4 Sep 29, 2013 - Uploaded by H2TechVideos For More Videos, Check Out My Website at http://H2TechVideos.com NEED HELP GROWING YOUR YOUTUBE ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
How to perform a hard reset when my Apple iPhone 5c is ...
support.bell.ca/.../Apple-iPhone-5c.how_to_perform_a_hard_reset_whe... iPhone 5c - 8 GB (iOS 7) Insert the USB cable, then hold the Home key while connecting the iPhone to iTunes. On the computer, when prompted that iTunes has detected the iPhone in recovery mode, click OK. gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Use iTunes to restore your iPhone, iPad, or iPod to factory ...
https://support.apple.com/en-ca/HT201252 Oct 21, 2015 - Restore your device. Connect your device to your computer using the cable that came with it. Select your iPhone, iPad, or iPod when it appears in iTunes. In the Summary panel, click Restore. Click Restore again to confirm that you want to restore your device to factory settings and delete all data and content.
How to Factory Reset an iPhone (Any Generation) ' Digital ...
www.digitaltrends.com > Mobile Dec 15, 2015 - How to factory reset an iPhone with or without using iTunes, no matter what generation it is.
Apple iPhone 5c hard reset
www.hard-reset.com > APPLE hard reset Reset iPhone 5c: Press and hold the On/Off Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Perform a factory reset - Apple iPhone 5c 16GB Certified Pre ...
support.sprint.com/...factory-reset...iPhone-5c.../WScenario_542_50265... Perform a factory reset - Apple iPhone 5c 16GB Certified Pre-owned. Last updated: Oct 01, 2015. article View all tutorials. Did this solve your problem? Explore ...
Videos
Feedback
Feb 01, 2016 | Apple iPhone Smartphone
ipod instruction manual how to erase
If you want to erase the contents on the device, you can connect it to itunes on your computer and erase everything from itunes.
Aug 15, 2014 | Apple Ipod Nano Second Gen. Green (4 GB)...
iPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
screen broken
c_empty.gif  WE REPAIR ALL OUT OF WARRANTY APPLE IPODS,IPHONES, AND APPLE LAPTOPS SERVING EAST DELHI,WEST DELHI,NORTH DELHI,SOUTH DELHI,FARIDABAD,GURGAON,NCR PLEASE CONTACT US AT JULIAN JOHN : 9810124668 ZION TECHNOLOGIES 245a,sant nagar,first floor, East Of Kailash New Delhi 65 (since 1997) 41620696//9810124668/41620840/
Aug 31, 2008 | O2 Xda IIs Pocket PC
141 people viewed this tip
David Payne
David Payne
