Tip & How-To about Computers & Internet
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
Overclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    Computers & Internet Logo
    How do I increase FSB past its factory preset in my HP Pavilion 515n pc?
    Some people, when their computer reaches the point that it can't run the programs it once used to, decide to toss their machine and invest in a new one. Others squeak out some extra life by overclocking their processors. While this is ideally done with hardware, for pre-built HP computers you will have to use a software option. With this minor exception, the process is still a breeze.
    Download and install CPU overclocking software, such as ClockGen, SetFSB or SysTool (see Below). http://files.extremeoverclocking.com/file.php?f=189 http://www.softpedia.com/get/System/Benchmarks/SetFSB.shtml http://www.techpowerup.com/systool/ While all these programs more or less work the same, for this guide we will be working with ClockGen. Boot the CPU overclocking software. Do not be alarmed if your computer momentarily slows down, as the software is reading your CPU's clock speeds. Click "PLL Control" or the equivalent in your overclocking software. This will show you several sliders for your front-side bus (FSB) and, in many cases, your PCI cards. Adjust the FSB slider. Be sure to do this slowly, as the processor will likely fail if there is a sudden speed change. For best results, use the arrows to slowly adjust the settings by one-to-two megahertz at a time. Click "Apply" frequently to set the speeds. Hope this helps.
    Jan 20, 2013 | HP Pavilion 515n (DC471A#ABA) PC Desktop
    Jan 20, 2013 | Computers & Internet
    im trying to decide what video card to get with this mother im a huge gamer and i play all games from CoD4 to wow. also does this board already come factory overclocked? how do i configure overclocking ?
    motherboards do not come overclocked, unless you bought it from a person that has already done that. For overclocking, you go into the BIOS but make sure you have adequate cooling in your machine. When you overclock you want the CPU cooler fan to blow away from the CPU instead of onto it. Also you want more fans blowing out the rear of the case if you have one intake fan in the front, two in the rear/side panel. Overclocking causes more heat, and shortens CPU lifetime. I believe you press F2 at boot to get into BIOS on your motherboard. in the BIOS settings you can change the multiplier, but if it doesn't add up correctly, your computer will just hang instead of boot and try a different setting. Although this mobo supports Hyper-Threading and supports Untied Overclocking Technology, so it should be simpler to overclock rather than some mobos are tricky to get it going right.
    As for the graphics card with this board: it's an Intel processor so you need a graphics card made by ATI. I would recommend a Radeon graphics card with this motherboard. The motherboard is compatible with Front Side Bus 1600/1333MHz CPUs, so make sure your Graphics card you select doesn't have a FSB faster than that, otherwise you will be wasting money.
    Jan 02, 2010 | Intel ASRock Penryn1600SLI-110dB LGA 775...
    overclocking
    hi friend this is:
    What is Overclocking?
    Overclocking is a cool way of making your CPU, video card (monitor card), 3D accelerator and some other kinds of hardware run faster and give better performance for free! (Intel's worst nightmare! MWHAHAHAHAHA!!!)
    During this tutorial I will teach you how to overclock your CPU, but you can use this information to overclock other kinds of hardware on your PC.
    Now, your CPU speed is based on two factors - your BUS(2) speed and your clock speed (mine is 1 second per second... just kidding. I don't mean a standard clock, like one you can tell time out of. Read on and you'll understand).
    Example: The BUS speed on older computers (let's take a Pentium I 166MHZ(3) as an example) is about 66MHZ. 166, the CPU speed, divided by 66, the BUS speed, gives you about 2.5, meaning your clock speed is about 2.5.
    Simple, huh? BUS speed X clock speed = CPU speed.
    Now, what exactly is overclocking and how do I do it?
    Materials
    1. The little booklet you were supposed to received together with your CPU.
    2. A screwdriver (better be a Philips screwdriver).
    3. A metal plier with a rubber/plastic handle or a bunch of fingers (better be your fingers... oh, and when I said a bunch of fingers, I've meant at least 5, all of them attached to a living hand (better be yours). Undeads are also welcome).
    4. A calculator / a brain.
    A) Open your computer using your trusty screwdriver.
    B) Look at the little booklet you have and find the part about the jumpers(4) board and read.
    C) Use the plier or the fingers to change the jumpers array so you will receive the clock speed you are interested in. Oh yeah, and try not to step on your CMOS chip(5) or on your Cache chip(6).
    Note: newer CPUs are "Clock Locked", meaning you cannot change their clock speed, but you can still change their BUS speed... ;)
    Changing the BUS speed is similar to changing the clock speed (read the part on your booklet about the jumpers).
    How Dangerous is This Whole Thing?
    Well, you CAN fry your modem, but it all depends on you.
    If you screw up and step on things, spill coffee over your computer or overclock your CPU too much (see Advanced Tips), don't come back crying to me.
    Possible Side Effects:
    Apr 15, 2009 | Computers & Internet
    cpu speed currently 1.8mhz spec indicates 3000+ msi k8t neo 2 can u set cpu speed faster?
    You do not mention the CPU name, but if the CPU is a Semprom 3000+, then 1.8Ghz is the correct clock speed for the chip.
    The "3000+" is what is called a "performance rating" - It is NOT the chips clock speed in GHz.
    Look here: http://en.wikipedia.org/wiki/Sempron
    If you want faster, then you would need to overclock.
    Dec 30, 2007 | Computers & Internet
    1,051 people viewed this tip
    David Payne
    David Payne
