Tip & How-To about Sony Playstation 3 (PS3) Console
How to re sync a ps3 controller
  • Connect the controller. With your playstation 3 system powered down, connect the mini-USB --- which is the smaller of the two ends on the cord --- to the slot located in the center of the top of the PlayStation 3 controller. The USB end of the cord should then be connected to one of the multiple USB slots located on the front bottom of your PlayStation 3 console.Turn on the PlayStation 3. The console will automatically recognize the connected controller, which you can then use to operate the PlayStation 3. By powering up the console with the controller attached, the two will automatically pair up and sync.Shut off the PlayStation 3. Hold down the P button located in the middle front of the controller until a menu appears on your screen asking you whether you'd like to shut down the PlayStation 3, shut down the controller or cancel. Choose the first option and wait until the console powers down. Disconnect the cord from both the PlayStation 3 and the controller.Turn on the console with the controller. Holding down the P button on the controller, wait until the console powers up and the introduction screen appears. Your controller is now synced with the PlayStation 3 system.Troubleshoot your controller. If the above steps do not work, there is another step to take, according to PlayStation's troubleshooting guide. Straighten out a length of paper clip and then flip your controller over so you are looking at the back of it. There is a small hole in which you can insert the paper clip and reset the controller's settings. Once you do, repeat the steps above to sync your controller to the console.
  • Posted by on
    Sony Playstation 3 (PS3) Console Logo
    how to connect in psp
    i'm assuming you want to connect your psp to your computer, you need a usb to mini usb cord. plug the usb cord into the psp (the plug is on the top of the psp), then plug the other end of the usb cord into your pc. you might need to go to the far left option on your psp (settings) then scroll up once to usb connection and hit x, your computer will automatically install your psp and connect.
    May 02, 2011 | Sony PlayStation Portable (PSP) Console
    hi, am having problems connecting my orb ps3 wireless conntroller.i have no instructions
    all you need to do is connect the controller to the usb ports using the usb power cord and the controller should then sync automatically to the system.
    i hope i have helped let me know how it goes
    Jan 02, 2010 | Sony Playstation 3 (PS3) Console
    my wireless controllers won't work
    connect them to your ps3 using the usb cord and hold down the power button this should sync it with ur system
    Nov 18, 2009 | Sony Playstation 3 (PS3) Console
    dualshock 3 sixaxis why does it always need to be plugged in
    Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
    Feb 19, 2009 | Sony Dual Shock 3 Controller for...
    655 people viewed this tip
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
