Tip & How-To about Sport & Outdoor - Others
Frozen Car Window - How to free it up fast!
Hi. If you live in a place where winter means icing conditions, snow, sleet and such; you have probably experienced a frozen car window. When murphy's law kicks in the car window that usually freezes up first is on the driver's side. No fun when you want to go to a drive in window, or get the mail from a rural mailbox. What can be even worse is when the window is left open or partly open and freezes in that position... bbbrrrrrrrrrrr.
For a quick fix of this problem without doing any damage to your car's window or the gasket that surrounds the glass on the outside of the door your will need a tool called a flush cut saw. If you have a Home Depot, Lowes, or most any hardware store near by you can purchas a flush cut saw for about $10.00. I like the Stanley Fat Max Flush Cut Saw which is also available at this link http://www.nextag.com/Fatmax-Flush-Cut-Saw-69621680/prices-html
A flush cut saw is unique in that there are teeth but the teeth are not bent, or set, to tear. Instead, the teeth are in a straight line with the rest of the blade. For this application, the teeth will cut but not tear the gasket.
All you do is slide the saw between the glass and the gasket on the outside of the door. This will allow you to slice through the ice that is keeping your window from going up and/or down. It will also solve the frozen window problem without damaging the rubber gasket that is supposed to keep water from entering the interior of the car door.
I keep one of these flush cut saws in my car during the Winter months. It doesn't take up much space but it sure comes in handy when a window freezes shut!
Sport & Outdoor - Others Logo
What type of tires would you recommend for winter driving?
latitude-x-ice.jpg Latitude® X-Ice®
Winter
Winter Tires
Better Starting Grip in Icy Conditions.
A special Winter Flex Compound, specially formulated to maintain its grip under the most extreme cold-weather conditions, including snow and ice, to help deliver better starting grip and shorter stopping distances.
Better Traction In All Winter Conditions
Cross Z-Sipes Technology uses a specially designed curve that locks the sipes in place, helping to provide improved grip on snow and ice. And because the sipes are full-depth, their grip lasts winter after winter.
Quiet, Smooth Ride in Cold-Weather Conditions
Dec 02, 2010 | 1996 Jeep Grand Cherokee
My 2007 Mazda3 is the worst car I have ever driven on snow and ice? Is this a common problem and can anything be done about it?
First,any car that has low ground clearance can be a problem in deep snow. But the problem you are facing is probably related to the contact patch of the tires. If you have wide, flat tread, go-cart/race track style tires you will have problems in rain, on ice , and on snow. I am guessing you have too much tread on the ground for the weight of the car. You can try adding weight to the car ( sand bags in the trunk , it works for pick ups). I live in Minnesota. For one car I had to get narrower tires and rims ( about 2" to 3" narrower) for winter driving. It made all the difference in the world. If there is a different tire offered for your model that is narrower( off of the less sporty version) , you may want to buy a second set of wheels at the salvage yard for winter driving. This should take care of the problem.
Sep 07, 2010 | 2007 Mazda 3
I have a 2004 Pontiac Grand AM . My car slides all over the place when it rains, or during the icy winter. What type of tires should I buy?
If you live in the northern part and north east you should purchase a tire specifically made for bad weather and avoid the all season type tires. The latter will do best on dry surfaces, and barely get you by on ice, snow, and wet roads. Most tire manufacturers make a rain tire, and bad weather tread. The brand is up to you. One more thing, make sure the tires are inflated to the proper pressure, over inflation will cause the symptoms you specify.
Aug 10, 2010 | 2004 Pontiac Grand Am
new tires
ya, and all the hills make it 10x worse. i'm from pittsburgh. it all depends on how much you want to spend. but make sure they are winter performance and not all season, they are better for snow and icey conditions.
good ($150-$200):
Bridgestone Blizzak DM-Z3
Goodyear Ultra Grip SUV
Dunlop Grandtrek SJ5
best ($200-$300):
Michelin Latitude X-Ice
Pirelli Scorpion Ice & Snow
Toyo Open Country G-02 plus
Dec 28, 2008 | 2004 Lexus GX 470
4,032 people viewed this tip
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
