Tip & How-To about Computers & Internet
How to hook up a wireless router.
  1. Open the wireless router box and examine the contents. You should have the router, a setup CD-ROM, a network cable and a power adapter. If any of these are missing call the company on the box.Put the setup CD in thecomputer. A screen will come up and ask you if you want to start the setup. All this CD is doing is taking you step by step through the hook-up process. Click Start setup.Choose which language you want to continue in from a drop down menu and click next.Go over the user license agreement and check the box that says, "I accept this agreement." When you are ready click next.Allow the program time to check your internet connection. When it is done it will say, "Check successful." Click next and you will be ready to begin hooking up your new wireless router.Remove the internet cable from your computer. It will be the only one that goes in to a phone jack. Then plug it in to the wireless router in to the yellow spot. Each spot is colored for your convenience, but it should also be the only spot that fits the plug so you can't get it wrong even if you try. When you have done that click next.Get the network cable you found in your box. The cable should be blue. Plug one end of the cable in to the blue spot of your wireless router and the other end in to your computer. It will only fit in one spot so don't worry. Click next when you are done this part.Plug the power adapter into the wireless router. It goes right next to the blue wire, and will only fit in that one spot. The other end should be plugged in to an outlet or power strip. Click next and wait for the system to check if the router is hooked-up properly. If it is hooked-up properly it will say, "Configuration Complete." Click next.Click next to close the setup wizard and begin using the new wireless router. This process should have only taken you a total of five minutes. If you have any problems contact the company listed in your instruction booklet.
Computers & Internet Logo
ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
how do you hook up the wireless router
First configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi .Then save settings and restart router. Then connect internet cable from service provider to your router's WAN port.If you want wired internet then connect lan cable from computer to router's lan port. Let me know if you need further assistance. Thanks for using FixYa.
Oct 16, 2010 | Computers & Internet
install software without a cd rom drive
Connect an Ethernet cable between the network-port on your computer and one of the LAN ports on the router.
Now, you have a "direct" connection to the web-server that is "inside" the router. Open your web-browser, and connect to the web-server, and then you can run the "Wireless Networking Setup Wizard" to create your wireless network, i.e., pick an SSID and a password, and enable "WPA" (Wireless Protected Access) security.
Now, you can disconnect the Ethernet cable, and you can "find" the SSID that you have chosen.
May 28, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
how to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
set upcd won't open
Right click the start button and click explore, find the the rom drive with the CD, right click the drive and click expand, you will find a setup.exe double click this to execuite the setup. BPCS
Dec 29, 2007 | D-Link 802.11g Wireless Router WBR-1310...
344 people viewed this tip
David Payne
David Payne
