Tip & How-To about Heating & Cooling
Kerosene Space Heater Tip
I have repaired many kerosene space heaters in the past. The number one problem that I see is everyone expects the heater to just come on every winter when they plug it up. But usually it does not. It's been sitting in storage collecting dust. And then you hear them say "It worked fine last year". If everyone would just do this at the end of each winter and you are ready to store your heater, (Drain the fuel & clean your tank out). Check your filters and replace if needed. It is that simple. When you need it, do not put the same fuel that you have in a can or barrel (from last year) in the heater. Discard the old fuel properly & just purchase some fresh fuel and start off fresh. If you use the old fuel that was left in the heater or can/barrel, you are just looking for trouble. If you fire the heater off with the old fuel, you are just filling the heater with problems. Water is the problem. The fuel tanks/cans, ect. sweat during the hot months and it all settles in the bottom. Inspect your fuel before using it. Look for water/trash that has settled in the bottom. Discard as needed. You will be nice and warm instead of having heater problems when your freezing & needing heat. Just remember "start off fresh".
Heating & Cooling Logo
master torpedo heaters
Go to www.bealsmotor.com and if the model number isn't listed email them and they will send you an owners manual for your heater
Jan 01, 2012 | All-Pro Kerosene Garage Shop Heaters - All...
propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
can you use diesel instead of kerosene in ready heaters?
No - diesel fuel is NOT the same as kerosene. Kerosene is #1, regular diesel is #2. They are not interchangeable.
Mar 02, 2010 | Reddy Heating & Cooling
were do i get parts for all pro 115000
Go to Google. Type in Kerosene Heaters and you will find a web site that sells parts. Keep model number handy. Rus
Nov 22, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
We arelloking for parts for our All Pro 60,000 BTU heater. The part # is 0634-3 the model of the heater is WP060X0FP
You may want to try Master Parts at 800-446-1446 or online at www.masterparts.net. You would need the correct model number. The only you gave is a serial number. You should be able to find the model number located on the heater near the serial number.
Jan 03, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
277 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
