Tip & How-To about Video Game Consoles & Games
HOW TO INSTALL CFW 5.03 GEN-C 9 (FULL) ON YOUR PSP
HOW TO INSTALL CFW 5.03 GEN-C (FULL) ON YOUR ALL PSP WITH ORIGINAL FIRMWARE VERSION 5.03
Requirements :
1. OFW 5.03 version
2. Chickhen R2 software (with slim mod2.tiff for psp slim or phat.tiff for phat psp)
3. CFW updater Gen-C software
4. ISO/CSO games
5. egghunt.bin
6 h.bin
7. A Computer
Note 1 : CHICKHEN R2, CFW updater GEN-C, egghunt.bin, h.bin and ISO/CSO games are downloadable in any website. But if you need it badly, I can send it by email. You cannot run install CHICKHEN R2 if any one of the softwares are missing.
Note 2 : This is for OFW 5.03 version only and it will not work in other OFW version 5.50, 5.55, 6.10, 6.01 & 6,20.
FIRST you need to download the required softwares like CHICKHEN R2, CFW updater GEN-C (if you have other CFW updater like GEN-B or GEN-A), EGGHUNT.bin, H.bin and at least 1 ISO/CSO game and store it in you computer.
THEN WE WILL START TO TRANSFER THESE SOFTWARES TO YOUR PSP.
TRANSFERRING DATA PROCEDURE:
1. Connect your psp to your computer using usb cable and it will display autoplay window. Just click view files. If it doesn't run on autoplay window, just go to SYSTEM SETTING and choose connect to USB MODE.
2. Put the CHICKHEN R2 to PICTURE FOLDER.
3. Put the GEN-C to GAME FOLDER.
4. Put the EGGHUNT.bin and h.bin to you MEMORY CARD along with the folder like GAME FOLDER, PICTURE FOLDER, ISO, PSP, etc.
5. Put the ISO/CSO games on ISO folder.
5. After transferring the data, remove your usb connection from the your computer.
6. Then go to system settings, TURN OFF the UMD AUTO START, TURN OFF the UMD Cache and TURN OFF the USB auto connect.
7. Also, on system settings, you need to change the character set to US (437) - Latin 1 (1252). After these steps, you are now ready to run the CHICKHEN R2.
PROCEDURE ON RUNNING CHICKHEN R2 with slim mod.tiff or slim mod2.tiff
1. On your PSP, go to PHOTO FOLDER, then choose MEMORY STICK, and once the picture square images appears, SCROLL DOWN VERY FAST at the last picture (it was slim mod.tiff to activate) within 1-3 seconds. GREEN LIGHT FLASHES if successful and your PSP is upgrade. Just wait for it to reboot itself.
Note : If not successful or green light doesn't flahes, just repeat the procedure of RUNNING CHICKHEN R2.
2. After updating, GO TO GAME FOLDER and active the CFW GEN-C updater. AND IT"S FINISH.
THE ISO/CSO Games are now viewable and playable in the GAME FOLDER.
NOTE : DO NOT REMOVE OR DRAIN YOUR BATTERY BECAUSE YOUR FIRMWARE WILL BE CORRUPTED AND NEED TO REPEAT THIS PROCESS AGAIN.
And I hope it will help you guys out there. Please rate and comment this blog. Good luck to all.
Video Game Consoles & Games Logo
i've upgrade my psp 5.03 chickhen r2 to 5.50 gen-d3. then i reboot my psp, and then my screen turn blank. i remove my mem card and batterry. and nothing happens.. plss help me.
upgrading/downgrading or installing CFW in PSP is a risky business. the rule of thumb is to know if you have hackable or unhackable motherboard. if you had 5.03 chickhen before, then most likely you have a PSP-3000 or PSP-2000 v3 which has unhackable motherboard. you should have just installed 5.03 Gen-C or CFW Enabler 3.70, or upgraded the OFW to 6.20 and installed 6.20 TN-E or 6.20 PRO-B. 5.50 Gen-D3 is for hackable motherboards like PSP-1000 or early versions of PSP-2000. you have bricked your PSP!!!
for more details, check out sites like pspslimhacks.com, pspcustomfirmware.com or qj.net.
Sep 01, 2011 | Computers & Internet
Formatted my psp and now it can't detect games.
  1. You need to download first ChickHEN R2 software from the internet and copy it to the PICTURE folder of your Memory Stick.
  2. After that you need to run the ChickHEN software to update your PSP firmware version.
  3. After that you need to copy the 5.03 GEN-C to your Memory Stick and run this update.
Jan 24, 2010 | Sony PlayStation Portable (PSP) Console
psp1000
You can use ChickHen R2 to downgrade your PSP without a pandora battery. You need also to download the ofw ver. 5.03 and cfw 5.03 GEN-C to hack your PSP. You can find many ChickHEN R2, cfw 5.03 GEN-C and step by step instruction in the internet.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
runescape on my psp
freewebs. com/ roshanb/ runescapeonpsp.htm helps(take out spaces)
Latest CFWEnabler : 05/07/2009
Download:
http://2f19b96d.seriousfiles.com
Changelog:
- Fixed a bug when playing within Infraestructure
- New system version
- Improved the Pops flashing system
- New update server.
Just copy the CFWEnabler folder into /PSP/GAME , then go to Games and run the installer
1)INSTALLING 5.03 OFFICIAL AND LOADING CHICKHEN R2
a)INSTALLING 5.03 OFFICIAL
Firstly, you CANNOT do this unless you hava a PSP with Version =<5.03 . To check your PSP FW go to Settings-> SystemSettings-> System Information . If the version is 5.03 , skip thispart and follow the guide below to install ChickHEN . If you have alower version follow this GUIDE in order to install OFW 5.03 .
-Download 5.03 OFW (http://135ff34d.seriousfiles.com)
-Connect your PSP to your PC via USB and create a folder in PSP/GAME named UPDATE.
-Copy the .EBOOT file in PSP/GAME/UPDATE.
-Run the update from your PSP .
Now you should have a 5.03 OFW PSP , just what you need in order to load the Tiff Exploit.
b)LOADING CHICKHEN R2
Some useful tips for those who can't get the ChickHEN to work :
-Restore Default Settings
-Set UMD Auto Start and Cache OFF.
-Make sure you're on 5.03 OFW
-Format Memory Stick. ( this will erase all the data from your MSso you'd better backup your files on your PC before doing it )
-Try another method as this video shows :
(http://ad452dd7.linkbucks.com)
-Don't give up , just try and be patient.
Note that the files needed for PSP 2000 and 3000 series are different than the ones needed for PSP 1000 so don't screw it up.
DOWNLOAD:
FOR PSP SLIM ( 2000 & 3000 ) :
-Download ChickHEN R2 Easy to Load
(http://0639570b.thesefiles.com)
FOR CLASSIC PSP ( 1000 ) :
-Download ChickHEN R2 Easy to load
(http://d249d993.thesefiles.com)
-Copy h.bin to the Memory Stick ROOT .
-Copy ChickHEN folder to PSP/PHOTO ( create one if needed )
-Navigate to your PHOTOS folder , and enter the ChickHEN folder.And wait, you will see some images, these will start to loadthumbnails.Go all the way down to the last image. Your PSP may freezeand reset. Just keep retrying and ChickHEN R2 will load up….But if yousee flashing colors, your PSP will reboot loading the ChickHEN.
For those who can't load the ChickHEN files check above for useful tips and remember to restore default settings.
Check your PSP's version to make sure. If the version is somethinglike 5.03 ChickHEN R2 you should be fine and ready to install CFW.
2)INSTALLING CUSTOM FIRMWARE
Do NOT try this on any PSP 3000 or PSP 2000 unhackable mobo's this is only for PSP Phat and 2000 hackable series.
This will permanently install CFW onto your PSP
ChickHEN must be enabled.
-Download Recovery Flasher 1.60
(http://926291d9.thesefiles.com)
-Download 5.0 OFW
(http://a3b04c08.thesefiles.com) -direct download
-Copy the Recovery folder to PSP/GAME .
-Also copy the 5.0 official update renamed as 500.pbp to PSP/GAME/RECOVERY folder .
-Go to GAME and run the program and install 5.0 M33-6 !
In the end , press SELECT while in XMB and change UMD Iso Mode to''M33 Driver'' or ''Sony NP9660''. I also recommend formatting memorystick. Place your CSO/ISO games to the ISO folder on your memory stickroot.
GUIDE created by : PSPgamen OF AFTERDAWN
Any questions ? probs ? post here !
Enjoy :)
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
3,166 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
