Tip & How-To about Computers & Internet
My Internet connection so slow?
The type of Internet connection you use is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up.
Many Internet providers also offer Fiber Optic Service (FiOS), which connects to the Internet using light over an optical network. In your home, you still connect your computer through copper wiring. The advantage of FiOS is that it can provide higher speeds than traditional copper wire connections such as DSL or cable. Some Internet providers offer multiple options, depending on the area you are in. More populated areas are more likely to have FiOS available. Check with your phone company or Internet provider for more information.
If you use a dial-up connection, there are a couple of good ways to optimize your Internet speed. First, use the fastest modem you can. The fastest modem you can use will send and receive information at a rate of 56 kilobits per second (Kbps). You won't get a full 56 Kbps speed most of the time, but with a good phone line, you should approach at least 45-50 Kbps.
Second, make sure that your phone line is in good condition. If the telephone wiring in your home or business is old or deteriorating, you might be picking up stray signals or cross talk from other phone lines. These problems will slow your Internet connection because the modem will have to send the same information over and over until it's transmitted without interruption. Check your telephone wires to be sure they aren't damaged, frayed, or twisted around power or other telephone cables. If you notice crackling in your phones, you might want to contact your phone provider to have them check the lines inside and outside your home to make sure they are in good condition.
Computers & Internet Logo
internet speed slowed down after install of win 8.1
The type of Internet connection you use in windows 8 is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up.Check with your phone company or Internet provider for more information.Then if you check your speed from http://www.scanmyspeed.com you will definitely see the difference
ScanmySpeed.com
Mar 02, 2014 | Arris Computers & Internet
What is limit of Internet speed
It depends on a service provider, plans and also which type of connection you installed. It is very difficult if the internet speed is very low. That why I have like to suggest you that look at the best nbn plans service provider. I think this is the best provider in the market and many people are taking services from there only. You can also try it there if you want best internet speed with best plans.
Dec 31, 2012 | Computers & Internet
hoe to know the speed of the internet when it is connected to computer???
You can test your internet connection speed by using the Scanmyspeed.com .It provides you the accurate results ..
Apr 05, 2011 | Computers & Internet
I was told the reason for drop in internet speed was the drivers are out of date.
drivers will not affect your internet connection,these are the factors that will lower the speed of your internet connection
virus
malware
weather may also affect
browsers
internet connection itself from the ISP
memory is full
Jun 28, 2010 | Compaq Presario R3240US Notebook
macbook pro and belkin router
Can you check if you have problems with your internet connection?
How about your browser? i recommend using mozilla firefox browser because i assure that it it the fastest browser.
If you have no problems with your internet connection probably you may want to check if your device are working properly.
Consider:
The health of your computer can affect your Internet connection.Spyware and viruses can definitely cause problems, but your Internet connection speed can also be affected by add-on programs, the amount of memory the computer has, hard disk space and condition, and the programs that are running.
Two of the most frequent causes of poor Internet performance are spyware and viruses. Spyware can slow your system by interfering with your browser and monopolizing your Internet connection. Spyware monitors your Internet use and keystrokes, which adds delays. The problem is compounded when there are multiple spyware programs running at the same time. If the problem is severe enough, you can lose connectivity altogether. To get your Internet performance back, you should regularly run an antispyware program to clean out any spyware infestation.
Computer viruses can also cause poor Internet performance. When a virus infects a computer, it installs computer code which will attempt to propagate itself, usually by sending copies of itself through e‑mail. Some viruses can multiply at the rate of hundreds of e‑mail messages per minute, which leaves little computing power and Internet connection bandwidth for anything else. Viruses often do not give any obvious indication that they are running, so it is best to run your antivirus software at all times.
Thank you : ) i hope my information works.
Please pm me if none of the options work. :)
Aug 08, 2009 | Belkin (F5D72304F5D7000) Router
177 people viewed this tip
David Payne
David Payne
