Tip & How-To about Computers & Internet
Ways To Take Care Of Laptop Batteries
Take care of laptop batteries is also become the part of using the laptop. It is consists of so many different easy. However, before take care of batteries we must have the knowledge of due to which ways the laptop battery can be affected. Like, the Lithium Ion notebook batteries wear down due to two factors, the first is "active usage in your notebook battery" and the second is "natural aging of the notebook battery". These both will wear down your notebook battery over time so the deception is to reduce their crash while still getting the performance out of your laptop battery that you need.
The most vital thing about understanding the laptop batteries is that they are always down a small bit of their charge. The hotter the temperature, the faster laptop batteries drop their charge. So the first step of care is to keep your laptop battery cool i.e. Notebook battery manufacturers store their products at around 60F (Be careful, it doesn't help to put them in the refrigerator; however, you can damage a battery by freezing it).
In the second step understand the capacity that decreases with each cycle of charging as well as discharging. By itself, it is not astonishing - but when collective with the previous point, it directs to a surprising conclusion.
Whenever you leave their laptop battery inside the machine along leaving the computer plugged into the wall that time the laptop battery is going from a constant charge-discharge cycle. However, once its charge level goes down to an encoded level (it is differ to manufacturer-to-manufacturer), the AC adapter offers extra fluid to "top off" the notebook battery. Moreover, as the laptop battery becomes older, it leans to self-discharge a little faster that speeds up the process even further.
Few Guidelines for Laptop Batteries:
- As new laptop batteries generally arrive in a discharged state so you must charge them minimum for four hours before their first use.
- Keep laptop battery cool (do not put it in the refrigerator or freezer).
- Try to evade running your laptop battery all the way to zero.
- Don't charge your notebook battery before long periods of inactivity.
So expand the life of your laptop by following the above listed points for take care of laptop batteries.
Computers & Internet Logo
the system charger broke and I cant fix it
If the external PSU broke you will need to replace that. Be careful over what type you use as they depend on what type of battery you have (Li-ion or NiMH). Also use the right voltage with enough amps and the correct connector.
How ever if you are saying something internal id not working (eg battery not charging but system is working when PSU is plugged in and has power from the PSU) then some components on your m/b have become defective. Replace the m/b which you can do yourself if you have the appropriate level of technical ability or else take to a good or authenticated repairer. There are bound to be guides on the internet/youtube.
13.Apil.2015
Apr 10, 2015 | Easy 5200mAh 11.1V Notebook Battery for...
Samsung No battery detected Hard Drives
the wattage of the ac adapter you're using is different from the required wattage of your computer. this happens when you use a different charger or the charger had not been cared for well.
May 12, 2012 | Samsung R538 fan - R538 laptop cpu fan
how to remove the keyboard
Keyboards become worn out over time. Individual keys can become damaged, become less sensitive to key strokes, or disengage from the keyboard. Keyboards can also become corroded from spills. Many keyboards on HP laptops can be replaced. Hewlett-Packard has made hundreds of different laptop models. Each model may require slightly different steps for replacing the keyboard. To locate a replacement keyboard, you can contact HP directly or another online or offline source that sells computer parts.
1.Power off the laptop. Flip the laptop over to access the device's underside.
2.Remove the battery cover and take out the battery.
3.Remove a screw to the left of the memory bay. This screw will be one of two resting in the middle of the underside of the device. You want to remove the right screw, the left screw is attached to the CD/DVD-ROM drive, not the keyboard. (This screw may be red in color.)
4.Flip the laptop back over and raise the laptop screen so you have access to the keyboard area. Insert the tip of a Flathead screwdriver along the bezel and detach it. Carefully pull the bezel up and set it aside. The bezel is connected to the device with a ribbon cable. Do not remove this ribbon cable. (The bezel is the above the laptop and is the cover that houses the power button.) Once the bezel is up, notice the three screws that are beneath it.
5.Unscrew the three screws holding down the keyboard.
6.Lift the keyboard forward toward the mouse area. Be careful, it is still connected to the motherboard by a keyboard cable.
7.Release the cable from the keyboard. Push both ZIF connectors on the side of the cable upwards, toward the laptop screen. Pull the cable from the connector and the keyboard is now released.
8.Insert the keyboard cable of the new keyboard into the ZIF connector. A pair of tweezers may be required to put the cable in place. Lay the keyboard flat down and rescrew in the screws. Replace the bezel cover. Flip the keyboard over and replace the screw on the underside near the memory bay. Insert the battery and battery cover.
Sep 19, 2011 | HP ProBook 4710s Notebook
How can I replace the keyboard on my laptop the keys stick I wasted water on it
It is probably better to show you a drawing of the Acer and where the screws are. From that it is easy to work ot where the bits all fit together. It apears there is a problem with Fixya, I cannot upload a drawing.
Try this:
Disconnect the power source and remove the battery.
Remove the hinge cover, it flexes fairly easilly but don't force it!
There will be a couple of screws fixing the keyboard down. Remove them and the keyboard becomes loose. Be careful with the flat cable and un plug it. (The socket has a clip that holds the cable in place, Use Care!).
Fit your new keyboards.
Hope this helps.
Nov 09, 2010 | Acer Aspire 9300 Notebook
black screen on my loptop
Most battery comparments are on the bottom of the laptop. There is usually 2 different "covers" on the back, one is for RAM the other is the battery. It should be relatively easy to remove. Be careful when removing the battery because there is a chance you could get shocked.
May 25, 2009 | Toshiba Satellite A215-S7422 Notebook
193 people viewed this tip
David Payne
David Payne
